ford fuel pumps 97-01
Welcome to the forum!
Wish I could answer the specific question,but I will lend some advice.
If you are talking about putting in a "used" pump,I recommend against it.
Its a PITA to replace a fuel pump anyway,and if you are going to have to go to all that trouble,you definately want new,and the correct one for the application.
If the one you would like to install is in fact new,I suggest you go to RockAuto Auto Parts pull up your truck,and write down the fuel pump part number,then pull up the other one,and see if they are the same.If so...your good to go,but if not,you have your answer.
General Geoff
23
06-05-2022 09:01 AM
fordexplorersport
02-11-2016 06:55 AM
forddytube
11-17-2003 10:57 PM
