Radio volume out of control - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-09-2010, 11:52 AM
littlhuan littlhuan is offline
littlhuan is starting off with a positive reputation.
Anyone know a fix for Ford radio volume control. Mine went straight to Max Vol this am and is stuck. I've seen this before. My Ranger has 132k miles so is it time for Audio Zone or what? Thanks.
Old 10-09-2010, 05:26 PM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
I think the radio itself is shorted out. I knew of this happening to someone else. Time for a new one
Old 10-10-2010, 01:20 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
What's your data? Year, radio type?
Old 11-21-2010, 11:16 AM
rsylvstr rsylvstr is offline
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
my 2001 Ford F150 Screw Lariat CD/tape/radio does this. it's the one with the CD player in the center cosole (6 CD's). doesn't go striaght to max, but when i turn it down, it goes up! i shut the truck down, wait 5 seconds, restart and that usually fixes it...sometimes it takes multiple attempts though. I definitely want to keep the OEM look and ease of use, along with the 6-CD player (in the console). I found several for less than $40 on ebay....will pull the radio, check PN's and then see what happens...will update .
Old 11-22-2010, 08:06 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
Sounds like a bad solder joint from volume control to circuit board or the volume control itself is toast.
Old 11-22-2010, 07:35 PM
Quote:
that's what i keep reading....going to pull the radio to verify the part number and just order one from that place on ebay....
Old 11-23-2010, 05:51 AM
Some Rangers came with a feature that automatically adjusts volume according to speed you are driving. Check the link to see if have the feature and how to adjust it if so,
Speed-sensitive radio volume?
STEERING WHEEL RADIO CONTROL doug-j 2004 - 2008 F150 2 01-07-2010 03:51 PM
Radio volume control Ed21 Explorer, Sport Trac, Mountaineer & Aviator 1 01-11-2008 05:29 PM
stock radio no volume control swreutter Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 04-26-2006 10:31 AM
1996 Ford Explorer Eddie Bauer JBL Radio Volume Problems suave6565 Explorer, Sport Trac, Mountaineer & Aviator 7 01-18-2005 12:14 PM
What!! Radio volume broke / inop. Options Explorer, Sport Trac, Mountaineer & Aviator 3 10-16-2004 11:56 AM
Tags
01, 2007, 250, f150, f250, fix, ford, problem, problems, radio, repair, stereo, van, volume, voume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
