'97-F250-7.3L diesel....fuel filter location ???
Old 10-08-2010, 11:13 PM
kevinrea's Avatar
kevinrea
kevinrea is offline
hi guys,
I finally did my oil change.. 15 quarts of delo and a motorcraft filter.. about $50.00 bucks.., so, now.., where the heck is the fuel filter located on these things ?
oh.. and a little note for those of us that get some oil on our cement.. Pool Acid...Muriatic Acid..., gets rid of it pretty good.. wash afterwards with a lot of water.
thanks,
Kevin Rea
Palmdale, Calif.
Old 10-08-2010, 11:17 PM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
Fuel filter is right in the middle of the engine valley. Round bowl looking thing. Dead Center of the engine. spin that black top and the filter is inside there.
Old 10-08-2010, 11:18 PM
rn360908's Avatar
rn360908
rn360908 is offline
Its located in the valley of the motor. If you have the factory plastic engine cover on your truck then it is right under that. It round with a plastic lid with a imputed 1/2" square that you can remove with a 1/2" drive extension and ratchet.
dougbrown's Avatar
dougbrown
dougbrown is offline
The fuel filter is on top the block in the vavle. Maybe under the black motor cover. It the black round circle witha 1/2 drive square or tabs for a long screw driver!
Old 10-09-2010, 09:33 AM
kevinrea's Avatar
kevinrea
kevinrea is offline
Hey rn360908
inside this thing ???
kevin rea
Old 10-09-2010, 09:38 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Talking
kevin rea
Yeap, inside of there
Old 10-09-2010, 09:53 AM
kevinrea's Avatar
kevinrea
kevinrea is offline
what a trip.. i would have never thought anything like that was in there.
any idea what part number it is ?? fram or otherwise ???
kevin
Old 10-09-2010, 10:25 AM
triskadek's Avatar
triskadek
triskadek is offline
NAPA 3517 I think. Comes with a new o-ring.
Old 10-31-2010, 09:14 PM
kevinrea's Avatar
kevinrea
kevinrea is offline
anyone know of online instructions to change this fuel filter ?
thanks,
Kevin
Old 10-31-2010, 09:24 PM
dougbrown's Avatar
dougbrown
Kevin get a big, I mean big pan and slide it under the engine! Push the yellow leaver to drain the filter housing on front left of housing. (water drain for water and fuel sepater). The lay a big screwdriver between to ears on the top of filter. Then turn counter clock wise and it will spin out! Then spin the new one in with new O ring! There easy to change. Alot better then Chevy and dodge. I change mine every 5,000 miles but most people do them 15 to 20,000 miles. You can skip the draining the filter part but it does some time make it easier to come out!
Old 11-01-2010, 12:52 AM
Harley05Ultra's Avatar
Harley05Ultra
Harley05Ultra is offline
You might want to keep a spare one in your truck and a 1/2 drive breaker bar. When they clog the the motor usually sputters and dies rather quickly.
Old 11-04-2010, 12:25 AM
kevinrea's Avatar
kevinrea
kevinrea is offline
well, i changed my fuel filter. pretty easy. i like the replacement one that i got for it. it is just kind of all one piece..., that is the black cap is attached to it and you just use a 1/2" drive to tighten or loosen it.
didn't have to do a pan under it when i changed it.., just pulled it up in the desert where i live in the dirt.
kevin
Old 01-06-2013, 09:51 AM
ianhill5's Avatar
ianhill5
ianhill5 is offline
Is there a secondary fuel filter that may be in the fuel tank?
Old 01-06-2013, 10:59 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
there is a screen, but not what i would call a filter
Old 09-21-2016, 03:32 PM
Snowgoose96's Avatar
Snowgoose96
Snowgoose96 is offline
1996 7.3L F350 Diesel Dually
Front tank seems to not be getting fuel. Whenever I switch from my third auxillary tank in bed or even my rear stock tank to the front tank..it drastically loses power and feels like it's gonna give. Even with a full tank of fuel. Does each tank have a separate pump and filter? What does this sound like?
Thanks
Quick Reply: '97-F250-7.3L diesel....fuel filter location ???
