Dents built for muddin! (lets see em)
Old 10-10-2010, 03:12 PM
Big_Dom's Avatar
Big_Dom
Big_Dom is offline
Exclamation Dents built for muddin! (lets see em)
Couldn'ta said no better!
Old 10-10-2010, 09:09 PM
Kirbys73F100's Avatar
Kirbys73F100
Kirbys73F100 is offline
No replies?
Old 10-10-2010, 09:21 PM
Kirbys73F100
It's still under construction.
Old 10-10-2010, 10:02 PM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender
"Top Fuel" Bender is offline
built this when I was a teen years ago
Old 10-10-2010, 10:14 PM
Big_Dom's Avatar
Big_Dom
Big_Dom is offline
*******s took my pic... anyways, that effing amazing!
Old 10-10-2010, 10:18 PM
79FordBlake's Avatar
79FordBlake
79FordBlake is offline
Nice........I see it was on half tons. How many axles did you snap in half?
Old 10-10-2010, 10:56 PM
"Top Fuel" Bender
Actually only one , the rear was a Dana 60 , never really got a chance to get it too buried , biggest friend at the time was a blazer on 38" without the front axle hooked up
Old 10-10-2010, 11:15 PM
Zephyr150's Avatar
Zephyr150
Zephyr150 is offline
Whoa. I want stats cause both your trucks are flippin gorgeous.
Old 10-10-2010, 11:27 PM
Kirbys73F100
Ha, I don't know if mine's gorgeous nor will it ever be. It's a purpose build offroader. have a build thread over in the offroad section.
1979 F250
460
C6
NP205
Front axle- 2.5 ton Rockwell toploader open
Rear axle- 2.5 ton Rockwell toploader welded spiders and flipped hubs (6.72 gears)
53" Michelin XZLs
Full hydraulic steering (saginaw pump swap)
Front and rear pinion brakes
The building starts on page 16 (as of right now) because the offroad folks like ramble.
https://www.ford-trucks.com/forums/95...thread-16.html
Old 10-16-2010, 11:32 AM
"Top Fuel" Bender
thanks , Wish I still had this truck
built it when I was 17
15" of Lift : 12" suspension , 3" body
start life as a 1/2 ton shortbed
swapped out the 9" for a dana 60, 35 spline moser axles
4.56 gears
rotated dana 44 up front
400 ,Holley carb, hooker headers
44x18.5x15 Gumbo Mudders on 14x15 Eatons
full cage inside, rollbar outside
custom bumpers
9000lb hyd. mile marker winch ( $500!! score new unused demo unit when they were 1st released)
onboard air
ect....
had wayyyyyyyyy too much fun in that truck
Old 10-25-2010, 12:01 AM
Kirbys73F100
Made enormous progress this weekend with shocks, anti-wrap bar, bumpers and custom bed incomplete. The bed has a cab length toolbox and two side toolboxes recessed in two 1/4" steel plates as well as a recessed 22 gallon fuel cell. It's not mounted yet though. There's several "lower priority" things that aren't done but it drives, it turns (very well!) and it stops (better than stock on 33's). It also flexes like a boss.
Tires mounted on new rims
All gussets and x-members welded
Steering plumbed
Cylinder mounted
Fenders and grill trimmed
Old 11-01-2010, 12:37 PM
Kirbys73F100
couple videos from wheelin over the weekend
Video 1
Video 2
Old 11-01-2010, 01:35 PM
samickguy15's Avatar
samickguy15
samickguy15 is offline
Video 2 comes up with "This video either has been removed from Facebook or is not visible due to privacy settings."
Old 11-02-2010, 12:44 AM
Kirbys73F100
Old 01-03-2011, 04:04 PM
Kirbys73F100
Pix from backyard wheelin. ill have video later
Quick Reply: Dents built for muddin! (lets see em)
