Carqueat fuel filters? - Ford Truck Enthusiasts Forums
Old 10-08-2010, 09:21 AM
2cylguy's Avatar
2cylguy 2cylguy is offline
2cylguy is starting off with a positive reputation.
I know what everyone is going to say, but, has anyone used the Carquest fuel filters with the integral top? I need to change my fuel filter and they are having a sale. First step in finding a low power under load issue. Thanks, Tom
P.S. Hopefully I will have guages and a 6.0 tranny cooler in the VERY near future so I know what the heck my truck is doing!!
Old 10-08-2010, 09:47 AM
robs01f250 robs01f250 is offline
robs01f250 is gaining momentum as a positive member of FTE.
I have not used them but I cant see why it would hurt. As long as you keep a fresh fuel filter in your truck you should be fine.
Old 10-08-2010, 09:54 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Our company uses Carquest products on our shop vehicles and contract repairs. We have an account with them and they deliver. We just installed one of their fuel filters in an e'99 PSD. It fit just fine, with no problems. The gasket on the lid of the Carquest filter has the square cut o-ring. Just lube it with a light film of oil before installing. IIRC, they are made by WIX and we have had no issues with thier filters. Go for it!
Old 10-08-2010, 09:56 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
I haven't used them either but one thing to remember, if your truck has the lid that if separate from the filter (Motorcraft/Rancor OEM style) keep the lid in case you switch back.
Old 10-08-2010, 09:58 AM
mueckster's Avatar
Quote:
Good point, Chris. I keep my lid in a Ziploc baggie in my tool box and usually take a spare filter with me on trips.
Old 10-08-2010, 10:16 AM
2cylguy's Avatar
Oh, believe me I will keep the original. That is the one thing I haven't done is to keep a spare anything with me. My stupidity. Especially since we purchased a camper last year and have done more towing. I will be purchasing a spare fuel filter and CPS to keep in the truck.
Old 10-08-2010, 11:14 AM
Bob Taulbee's Avatar
Bob Taulbee Bob Taulbee is offline
Duct Tape Tech.
Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.Bob Taulbee has a spectacular reputation.
Don't forget a spare serpentine belt.They are hard to come by in some of the small town auto parts stores. A broken belt and you are out of business.
Old 10-08-2010, 02:33 PM
bigpowerstroke's Avatar
bigpowerstroke bigpowerstroke is offline
bigpowerstroke is starting off with a positive reputation.
I work for Carquest. We don't show the old numbers in the catalog now but you can still get the old filter without the integrated cap. I'm resisting to swap mine to the new style because if you're out of town and need a filter bad..... you may get stuck only finding old style filters and you'll be without the old filter cap.
86518 - Old filter style
Old 10-08-2010, 02:41 PM
2cylguy's Avatar
Quick question. This is the first time I have changed the fuel filter and it came with the square o-ring and a smaller round o-ring. Does the smaller o-ring go on the bottom of the filter? Also how often should you change the frame mounted fuel filter? I don't think it's been changed since I have owned the truck. Thanks.
Old 10-08-2010, 03:02 PM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
Quote:
Can't fully remember about the o-rings, but I do want to warn you....
After you have put the filter and cap on and are ready to start up your truck.... have the hood up to see the engine area. If the seals are not on right and tight you will have leakage, you will want to know about it really fast, as the pump pressure will blow fuel everywhere and it makes one heck of a mess....
I then tightened the filter cap on so tight that the next time I changed it out I had to use a sledge hammer and a driving bar to bash the lid around to get it off
Old 10-08-2010, 03:39 PM
Hit it!
Here's a step-by-step. Welcome to guzzle's PSD Fuel Filter Change Web Page
OEM fuel set-ups do not have a frame mounted filters on the 7.3's, just the one on top of the engine. If you have a filter located on the frame, it's aftermarket.
Old 10-08-2010, 04:07 PM
2cylguy's Avatar
I haven't looked. I was going by what someone else said about their 6.0. Don't I feel silly.
Old 10-08-2010, 05:11 PM
Hit it!
No worries. Indeed, the 6.0's had frame mounted fuel filter and an engine mounted one.
Old 10-08-2010, 06:49 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
The smaller o-ring goes in the element gland near the bottom of the filter. Also make sure this o-ring comes out with the old filter. They have been known to fall to the bottom of the fuel bowl when removing the old filter.
Old 10-08-2010, 07:04 PM
derek0525 derek0525 is offline
derek0525 is starting off with a positive reputation.
That's all I use is the Carquest ones mainly because I get a discount through work. The guy at carquest said I get a better discount than they do which is kinda odd to me. I kinda always wondered who made the filters for them. Who makes the lower end filters? I always get the premium ones anyway but just curious.
Fuel filter bduemig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-28-2014 11:30 AM
Fuel Filter media (paper vs. ss mesh) AK FORD GUY 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-21-2013 02:55 PM
Fuel Filter TennesseeRV 1999 - 2003 7.3L Power Stroke Diesel 41 01-04-2013 09:01 PM
fuel filter header Country_boy_2007 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 11-30-2010 01:36 AM
Two fuel filters? Scratcher Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 06-08-2010 10:50 AM
Tags
2003, 60, 73l, camouflage, cap, car, change, f250, f350, filter, filters, ford, fuel, mirror, quest, rancor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
