Carqueat fuel filters? - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-08-2010, 08:04 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I'm a Racor filter user here although I picked up a different type filter maker this last time but it will do. Not sure if theres a difference but before I open the lid I drain the fuel out of the bowl, relieves some pressure I found and add a nice fill of Diesel Kleen and button it up, start, check for leaks with your finger around the lid-bowl mating surface and go. I recheck again the next day or later in the evening just to be sure.
Old 10-09-2010, 01:36 AM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
For what its worth, My budies big truck shop fills there filter with trans fuild. They say it cleans the injectors as it runs threw. They let it idle and rev a couple times before driving so it fills back with fuel.
Old 10-09-2010, 09:43 AM
big poppa's Avatar
Quote:
Thats old school treatments back about 20-30 years ago, I heard about it all the time, shucks, I poured a quart from time to time in each 100-150 tanks and off I went, no problems. With todays components and fradgile o-rings and our delicate injectors, I'm extreemly hesitant to go doing it to mine. I'll use Diesel Kleen or Howes..
Old 10-09-2010, 11:42 AM
2cylguy's Avatar
2cylguy 2cylguy is offline
2cylguy is starting off with a positive reputation.
We used to use that as a top end cleaner on gassers when I was a technician. Does a good job in cleaning off carbon.
Fuel filter bduemig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-28-2014 11:30 AM
Fuel Filter media (paper vs. ss mesh) AK FORD GUY 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-21-2013 02:55 PM
Fuel Filter TennesseeRV 1999 - 2003 7.3L Power Stroke Diesel 41 01-04-2013 09:01 PM
fuel filter header Country_boy_2007 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 11-30-2010 01:36 AM
Two fuel filters? Scratcher Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 06-08-2010 10:50 AM
Tags
2003, 60, 73l, camouflage, cap, car, change, f250, f350, filter, filters, ford, fuel, mirror, quest, rancor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
