2003 6.0 recalls?? - Ford Truck Enthusiasts Forums
2003 6.0 recalls??
Old 10-07-2010, 10:31 PM
scottm1's Avatar
scottm1 scottm1 is offline
scottm1 is starting off with a positive reputation.
2003 6.0 recalls??
I met a man in my neighborhood that I have lived by for the last 3 years, but never talked to before. He is a ery nice man with a 2003 Super Duty 4 door crew cab 2 wheel drive with a 6.0. He said he bought it used in 2004 with 15.000 miles. It now has 58,000 miles. He said the only trouble he ever had with it was a turbo charger was replaced on it awhile back under extended warranty. He also said he has never taken it in for any recalls or anything. Were there any recalls on the 03 6.0 that he needs to have address before the entended warranty runs out? I thought I remember hearing about a oil leak issue where the dealer uses a different fitting on the oil lines with a support bracket or something like that on the early 6.0. He is 78 years old, a very nice man, and I am trying to make sure he doesn't let his warranty run out and not get his recalls done.
Old 10-08-2010, 01:56 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
The only recall I know of was for a computer flash and if he is happy with the truck the way it is leave it be.The 05/6 has a fitting on the high pressure oil pump that is a known problem but there is no recall.Good on ya looking out for the old fella!
Old 10-08-2010, 11:27 AM
aladin sane aladin sane is offline
aladin sane is starting off with a positive reputation.
If he has an 03 that has never been flashed, he should keep it as far away from a dealer as possible. My 03 lost 2 to 3 mpg after it was reflashed.
6.0 excursion question mrad Excursion - King of SUVs 10 12-07-2015 11:45 PM
Synthetic Motor Oil in Automatic Transmission Zuiko Clutch, Transmission, Differential, Axle & Transfer Case 14 10-18-2014 11:04 AM
should I have walked? hink10 Excursion - King of SUVs 46 09-16-2012 02:13 AM
Boom Times nobodyspecial General NON-Automotive Conversation 12 11-04-2007 02:51 PM
Tags
03, 2003, 60, f250, ford, recall, recalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
