No fuel cap?? - Ford Truck Enthusiasts Forums
No fuel cap??
Old 10-07-2010, 10:29 PM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
No fuel cap??
Just purchased a new '10 F150 FX4 Supercrew this past Tuesday.
Really like the truck, except for.....the lack of a fuel cap.
Guess there are not any gravel roads around Dearborn.....
How do I go about getting this disaster waiting to happen replaced with a good ole fashion, no frills, RELIABLE gas cap?
Has anyone already did this?
I've searched the site, but have not had any luck.
Old 10-07-2010, 11:14 PM
stephen.osborne1's Avatar
stephen.osborne1 stephen.osborne1 is offline
stephen.osborne1 is gaining momentum as a positive member of FTE.stephen.osborne1 is gaining momentum as a positive member of FTE.
Why don't you like it? I have no problems with mine... nothing gets into there- at all. I didn't much care for it either at fist, but after a few fill ups, saw how slick it was. Just don't run it empty or you have to use the little funnel behind the back seat.
Old 10-08-2010, 06:50 AM
silver05fx4 silver05fx4 is offline
silver05fx4 is starting off with a positive reputation.
3 different vehicles and not even a bit of dust inside the filler area
Old 10-08-2010, 06:58 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Quote:
Me either. I love it.
If it bothers you, you can buy a locking gas cap from Ford.
Old 10-08-2010, 08:04 AM
msgtord's Avatar
msgtord msgtord is offline
msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.
That little plug is pretty slick. Think I'll order one just for those times traveling and staying at motels.
Old 10-08-2010, 08:07 AM
shotgunz's Avatar
Quote:
Yeah -for $20 it's cheap piece of mind.
Old 10-08-2010, 10:05 AM
iamsuperdan's Avatar
iamsuperdan iamsuperdan is offline
iamsuperdan is starting off with a positive reputation.
Quote:
So that's what that funnel is for! I thought it was something to help with adding oil or something, like Porsche provides.
Old 10-08-2010, 12:14 PM
You need for adding gas with a gas can so you don't damage the filler tube since only a gas pump end will open the trap door inside to let in gas
Old 10-08-2010, 04:29 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
I had a major mental block on this, too. The gasket on the gas door definitely does a good job of keeping the area clean.
Old 10-08-2010, 04:34 PM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Anyone got a pic of this new style filler.
Old 10-08-2010, 04:38 PM
MCDavis's Avatar
MCDavis MCDavis is online now
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Here ya go:
http://www.stangplanet.com/~dave/200...pless_fuel.jpg
EDIT: I believe this is the Mustang's filler. Can't find a good pic of one in the F150. Looks like "EasyFuel" might be the manufacturer???
Old 10-08-2010, 04:45 PM
brickie's Avatar
Quote:
Originally Posted by MCDavis View Post
Here ya go:
http://www.stangplanet.com/~dave/20081120_2010_ford_mustang_capless_fuel.jpg
Thanks,that sure is different.
Quote:
Here you are. Just went and took this on mine.
Old 10-08-2010, 05:47 PM
v_tach's Avatar
v_tach v_tach is offline
v_tach is starting off with a positive reputation.
Not a bit of dust behind my fuel door after nearly 20,000 miles including quite a bit of miles running dusty crushed granite roads in NC.
Old 10-08-2010, 06:07 PM
seadragon seadragon is offline
seadragon is gaining momentum as a positive member of FTE.
I wonder about snow/water this winter. I guess I'll find out.
Fiberglass Front Air Dam carbon coupe 1999 to 2016 Super Duty 4 08-18-2014 01:35 PM
Sync and Nav cdmm151 Ford In-Vehicle Tech 5 08-08-2013 12:47 PM
1994 F150 straight axle swap Dearborn-1979-mudder 1987 - 1996 F150 & Larger F-Series Trucks 2 04-13-2009 10:30 PM
Any 2005 5.4's with Cam Phase Sensor "knock"? FS-150 2004 - 2008 F150 9 03-27-2005 11:58 PM
P1406 Code jacrol 1999 to 2016 Super Duty 4 06-26-2003 03:27 PM
Tags
2009, 2010, assembly, cap, door, easy, f150, ford, fords, fuel, gas, neck, putting, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
