No fuel cap??
Welcome to FTE!
You could stand there with a hose and spray water right at the filler spout and water will not go into the gas tank.
The funnel disengages the seal.
The design also makes it harder to siphon (as well as eliminating the gas cap CELs).
I have exactly 6 mi of South Dakota dirt roads on my truck and only 500 mi total, and I already have a dust problem on the fuel neck. The inside of the fuel door looks just like my dust covered tailgate.
So, now the question is...How to clean it off? Can't spray water at it as there is no where for the accumlated tsp of water to drain to except for the tank. I guess I could dry it off with a towel. Man what a hassle.
I guess I'll have to find the locking plug at the dealer or replace the whole neck my self.
Do you guys really believe that the plastic door and the cheap rubber seal will keep out water and dust? The water spots in the posted picture already prove this point. One bout with freezing rain and having to fill will render the cheap seal useless, or the plastic door broken.
I really wished I would have seen this at the dealership. I would have had it changed on the spot, or walked out the door down to the Dodge dealership.
This is the kind of Engineering pipe dream that causes future recalls.
Ford is late to the game: http://www.ford.com/about-ford/news-...l-system-28320
Need the phone number for the closest Fiat dealer?
If you've got dust behind the fuel door, something is wrong with your particular setup.
Beside, the fuel door seal isnt the only seal to protect the fuel supply.
A couple of miles with your new truck and you call out others that have thousands of miles on their trucks? We dont have to beleive, we know from actual experience. Do you think we just make it up? I'm quick to call out problems with my F150 but the fuel door isnt one of them for me of my dad's. They're the only two trucks with the design I have experience with but both are approaching 20,000 miles.
So if I drive 20K mi down the highway and don't have a problem.....that means there's no problem? But if someone drives six miles down a dirt road and does have a problem on a new truck with less than 500 mi, I should tell them they are full of it?
Yeah I can see the problem with the fuel door...It's a flimsy piece of plastic that doesn't create a good seal to the flimsy seal on the body. It moves with temperature variation, has a CTE, and isn't locked or drawn against the body. Wind currents from road speed can also make it move as wells as body flex. Oh, did I mention that every thing about the door / neck assembly doesn't allow for adjustment to bandaid said design short commings?
Please enlighten me on the proper adjustment that I should perform on this.
Roll of duct tape?
Please enlighten me also about the door being the only seal.....You must mean the seal on the trap door of the fuel neck. Yep there is a seal there.
I wonder what is going to happen to all of the dust on the trap door as I put the fuel nozzle into the tank? Better not spill fuel on the trap door as you pull out the nozzel. Good thing there is a fuel filter still....
I wouldn't be so ticked about this if I didn't have so much experince on the engineering end of recalls and the amount of money it wastes.
I find it very disapointing that alot engineering thought went into the filler neck (as much as I hate it, it appears to be sound minus the entry of dust particles.), and virtually none into the door it self.
If more thought was put into the whole assembly I would not have issue with from a design and real world function point of view.
There won't be a recall as there is nothing wrong with the system. It will not let dust and dirst into your gas tank. Many manufacturers have had this type of system for many years.
Ford is late to the game: FORD’S EASY FUEL SYSTEM SIMPLIFIES FILL UPS, HELPS ENVIRONMEN ... - Press Release - Ford
Ever wonder why they pulled out of the U.S. market, before purchasing Chrysler?
Please provide a sound description on how dust partcles (20 micron or less) on the trap door will not get washed into tank of my $43K truck, and how they will not erode away the injectors on said truck after the fuel filter has been overcome.
I'd prefer to have something more than I've got 20K on my truck with out issue. You could drive 20K without an airfilter and not even have a problem.
I'll be removing my easy fuel and still be on the same set of injectors, and have used half as many (or more) fuel filters at 250K mi.
An ounce of prevention is worth a pound of cure.
I really hate to add to this but, you are not the only driver that lives on a dirt road in dusty conditions. I have almost 7000 miles on my truck in 4 months. Dust will not be an issue. Again no issue on the inside of the filler door. I have even opened the door, and hosed it out inside when washing the truck. No big deal. The flapper valve on the filler neck must maintain enough pressure to keep the system sealed, or you will get a check engine light. Try removing the gas cap of an older vehicle and see how long it takes to get a check engine light. If there is a problem with the seal, you will know it.
A couple of months ago the check engine light came on for my work car. It was the gasket on the gas cap. New gas cap and problem fixed. The point being that the standard gas cap can also have problems.
Just FYI, the picture of my truck was taken in my driveway. Notice the dirt?
#28
#29
#30
http://www.motorcraftservice.com/vdi...asy%20Fuel.pdf
Pages 4 and 7.
The fact that any thing is mentioned is an indicator that FMC has encountered issues in testing.
If you search the internet, issues are starting to pop up on other forums where the easy fuel has been in use longer.
It appears that the options are to use the locking plug (if the plug has a sealing surface on it) or replace the neck assembly with one from a '04 - 08' F150.
I particularly like the comments on page 7 about using the funnel to dislodge contaminates that are preventing the trap door from closing. If that doesn't work, you get the wonderful experince of replacing a $250 fuel neck plus labor.
Let's not mention the pleasure of replacing the highly designed door seal.
Seems so much more wonderful than replacing a $20 fuel cap.
As this thread is going nowhere, despite providing sound facts, engineering and observed, I will no longer post to this thread and book mark it for future reference as this ingnorant pleeb has clearly lost sanity and is clearly a troll.
If my dealership elects to not replace my fuel neck, I will provide a writeup on how to do it yourself in the event that out of warranty trucks need this replacement, or for those that would like to do it.
Pages 4 and 7.
