Running the red ELC coolant in the 6.4? - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 10-14-2010, 07:26 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Originally Posted by origcharger View Post
The biggest differance is on the 6.0 the cooling system is plumbed in series where the coolant flows from one component to the next and a plugged oil cooler will restrict flow to the EGR cooler.
On the 6.4 the system is plumbed in paralel so the oil cooler could be completely plugged and it still won't effect coolant flow through the EGR cooler.
Huh...that makes sense.
A clogged oil cooler may cause oil temps to get real hot but won't cause EGR ooler failure, which seems to be the fastest ticket to engine failure.
I wonder how hot oil temps would get with a clogged oil cooler...
Old 08-19-2014, 10:52 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Bump....
After these trucks have been running for 7-8 years, anyone have any new info to converting the coolant in a 6.4L?
Old 08-20-2014, 07:47 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
Personally I would go for it. The ford gold was a problem with the EGR coolers high temps in the 6.0's, I don't see why it would not have the same silicate drop issues in the 6.4. The gold is fine for ford's gas engines, use what the engine builder uses in the 6.4. I understand the warranty fear, personally I would talk to the local ford shop and see if it would void any warranty claim.
Old 08-20-2014, 07:55 PM
RM2738's Avatar
Been deleted for 92,000 miles, not concerned with warranty. Pushing 100K soon.
Old 08-26-2014, 10:44 PM
brian1253 brian1253 is offline
brian1253 is starting off with a positive reputation.
Everybody seems to be obsessive about mixing coolant with water I don't typically because if I'm in a pinch I can top it off with water if coolant is added 100% but I have never owned a diesel till now. I'm looking into changing to the cat elc and just curious about 100% coolant being to potent for the 6.4
Old 08-26-2014, 11:18 PM
RM2738's Avatar
Quote:
There is a reason behind the 50/50 mix as it provides the best possible protection against overheating. Straight coolant isn't a good idea. Most manufacturers are now selling 50/50 premixed to prevent owners from adding tap water as opposed to distilled or RO Water.
Old 08-27-2014, 06:01 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
buying the pre-mix is the best route.
Old 08-27-2014, 09:25 AM
sxrfun sxrfun is offline
sxrfun is gaining momentum as a positive member of FTE.sxrfun is gaining momentum as a positive member of FTE.
I've run the Rotella ELC for over a year now. After a good flush and with the ELC coolant my deltas are closer now.....whether it's because of the flush or the coolant who knows mind you. I chose the ELC because no chance of silicate dropping out and you don't need to check anything on it for some huge mileage....Not that i'm lazy...just one less thing to worry about lol. When I switched mine I didn't go with the premix....I went straight coolant and then diluted with distilled water. The reason I did this....is during the flush process your block is filled with just distilled water....If you don't get every last drop of distilled water out....(say by not wanting to fight with block plug on passenger side as it's a p i t a to get to), it will dilute the pre-mix slightly. I took total coolant capacity....calculated coolant needed for I think a 60/40 mix....put all coolant in first...then filled remaining with distilled water.
Old 08-27-2014, 07:08 PM
Quote:
Mixing with water lowers the boiling point and raises the freezing point(that is the wrong way you want those numbers moving) some anti freeze company's will even post the boiling point and freezing point on the bottle at 100% 75/25 60/40 50/50 to give you an idea of the mix you would want for your area (lived in the mountains needed freezing point protection) and 50/50 coolant pre mixed is a ripoff half of it is water and sometimes they charge the same amount as for the pure antifreeze. It should be half price not one dollar cheaper. Kinda went on a rant there sorry but I fail to see the benefit of mixing it with water. Unless something might clog my oil cooler like silicates but I'm getting away from that.
Old 08-27-2014, 07:13 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
pH and additive concentrations aren't in the correct ranges without the proper coolant/water mix. Running straight coolant is pretty foolish, though possibly better than adding tap water.
Old 08-27-2014, 07:32 PM
RM2738's Avatar
Interesting read.
http://m.bulktransporter.com/archive/international-truck-outlines-benefits-extended-life-coolant
Old 08-27-2014, 07:37 PM
Tom's Avatar
You're clearly not a chemist, and making an expen$ive bet based on an incorrect hunch. I'm not a chemist either, but publicly available data shows you're operating on bad information.
Any mixture above 80% raises the freezing point of the mixture. Pure ethylene glycol freezes at 9 F. Not sure where you're from, but that's not uncommon in New England during the winter.
Secondly ethylene glycol isn't capable of transferring heat as well as a water based mix.
Meaning your cooling system would become overwhelmed much faster on pure antifreeze. So when you are pulling a trailer uphill your engine temp would rise faster, and your cooling fan may or may not be capable of keeping temperatures in check because it was designed for a proper mixture of antifreeze and water.
There's a reason they design these things the way they do, and you'll notice that in just about every piece of literature there are warnings about how important it is to maintain the proper mixture. Do you really think you know better than the teams of engineers and the thousands of man-hours that went into designing these things?
I don't, so I follow the factory specs. You should too.
SOURCES:
http://www.meglobal.biz/media/produc...Global_MEG.pdf
http://www.centralstatesbus.com/MSDS...bitterment.pdf
  #28
Old 08-27-2014, 07:39 PM
Tom's Avatar
Here's another one:
Quote:
Originally Posted by Tom and Ray
Make certain the antifreeze will protect your car at the winter temperatures you'll experience in your area. For most areas, you'll need a 50-50 mix of coolant to water. You may think, "I'll be extra good to my car, and give it 100% coolant." Guess what? You're wrong. The 50-50 mix has a lower freezing point. Not only that, but 100% coolant is less able to transfer heat away from your engine, and has been known to cause such nasty things as melted spark plugs of engine failure under the wrong circumstances.So, mix it up!
SOURCE.
  #29
Old 08-29-2014, 03:24 AM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
Not to throw another choice out there but i have gone to Fleeguard's ES Compleat in my entire fleet. Mixes with everything took the guess work out of what works together and what does not. Been using it for awhile now with no issues.
http://www.cumminsfiltration.com/pdf...LT15070-GB.pdf
  #30
Old 08-23-2015, 02:15 PM
1 son 1 son is offline
1 son is starting off with a positive reputation.
custom f250
I have a 08 super duty 4x4 6.4 I've removed exhaust dpf as well as egr completely from truck I bought super chip racing program to delete the engine lights, I have 250,000 miles on the truck just put new transmission in and water pump, my question is this red antifreeze or gold aintf is being used in my truck now before was just water I live in south ms where it only gets around 45 in the coldest of winter I'm worried about over heating
ELC and a garden hose nico963 6.0L Power Stroke Diesel 22 08-03-2015 05:42 PM
2004 Excursion 4x4 limited Magnolia Tom Vehicles for Sale 2 07-25-2015 09:26 AM
Howdy pasocoach 1999 to 2016 Super Duty 7 07-10-2015 12:04 AM
6.4 antifreeze 2010 Duhnis 6.4L Power Stroke Diesel 11 09-02-2014 11:09 PM
Oreillys ELC???? run6.0run 6.0L Power Stroke Diesel 22 12-09-2013 08:05 AM
Tags
5050, 60, 60l, 64, 64l, brand, conversion, coolant, coolent, elc, ford, international, powerstroke, red, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
