special procedure for removing fuel rails - Ford Truck Enthusiasts Forums
Old 10-07-2010, 08:01 PM
stooks stooks is offline
stooks is starting off with a positive reputation.
Does anyone know if there is any special procedure to removing the fuel rails on a 2003 Ford F150 4.6L engine in order to get to the spark plugs? Need to change a plug and trying to do it myself but have never done so before.
Old 10-07-2010, 08:15 PM
jgeese jgeese is offline
jgeese is starting off with a positive reputation.
You shouldn't have to remove fuel rails to change plugs. Go to the top of this section, on the third item down it reads in bold red letters - Read First, 1997-2003 F-150 Frequently Asked Questions. You will find details for changing plugs in the 4.6/5.4 motors.
Hope this helps, it did for me...
Old 10-07-2010, 11:32 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Unbolt and lift, might have to wiggle a little. Make sure to lube the O rings a bit when you put it back in.
Old 10-08-2010, 01:04 AM
removing ruel rails
Thanks guys you really helped me out a lot thanks for the info
remove fuel rails for plug change fidge1 1999 to 2016 Super Duty 15 09-07-2011 07:35 AM
98 4.2 F150 Fuel Rail Disconnect Bob7211 3.8 & 4.2L V6 2 09-13-2008 03:46 PM
fuel rail removal NekSiwel Fuel Injection, Carburetion & Fuel System 5 03-05-2008 01:35 PM
Injector installation filling Oil Rail? racenitro 1999 - 2003 7.3L Power Stroke Diesel 16 05-01-2005 12:46 AM
Ford Aerostar: removing old radio jreid Aerostar 6 03-10-2003 12:04 AM
Tags
2003, 2004, 46, 54, change, f150, ford, fuel, grand, marquis, plugs, rails, remove, removing, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
