1999 F350 V10 misfire big problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-07-2010, 07:57 PM
mowman98's Avatar
mowman98 mowman98 is offline
mowman98 is new and has a neutral reputation at this point.
Unhappy 1999 F350 V10 misfire big problem
This all started about 1 year ago running really bad took it to ford said a coil was bad replaced it ran great now it only has 75K miles on it ok. This year started to run like crap again took it to ford said 2 coils were bad replaced them ran ok. Now just 2 months ago it ran like crap very hard misfire so I went out bought a snapon solus pro scanner was tired of taking it to ford. Well I drove it around hooked up my snapon dealer told me this would tell me what cylinder was not firing ok so I drive and tells me #9 was a very non contributing cylinder had 2 extra coils put one on still ran like crap. Thinking what is going on called snapon told you need to use mode 6 ok did that no problems or codes would come up what so ever. So I thought ok maybe its a plug it has 78K on by now so took it to ford had all the plugs replaced started to drive it home bucking again so now I am really mad, I opened the hood and when they replaced the plugs took coil off #9 and put it on 10 so got my other coil put it back on number 9. Figured hey got the problem fixed but the scanner was still telling me it was #9 called snapon again you need to do the cylinder contibution test which I was doing still tells me #9. Running like crap so I cant take it anymore take it to ford they tell me its #3 repalced the coil one of the remaining 5 runs ok not great but not like it was so here I am 3K scanner which wont tell me jack on this ford engine. Went out and replaced the remaing 5 coils it runs and gets better mileage so its a good thing. But my Question is why didnt the scanner tell me there was a misfire on one cylinder that was not really having a problem and the one that was passed. Any one else have this problem with fords as to not being able to tell what coil is not firing correctly????
Old 10-07-2010, 08:20 PM
wolfbike1500 wolfbike1500 is offline
wolfbike1500 is starting off with a positive reputation.
My truck is a bear like that too. I finally just replaced all the coils, boots and plugs. Been fine since.
99 F-350 Lariat 4x4 V10 CC LB
Old 10-07-2010, 09:51 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
yea im not a fan or replacing just 1 coil..
better to do them all at the same time, and be certain of the lifespan going forward..
NEED HELP PLEASE: 2004 F150 XLT 5.4l (3v) misfire kulla 2004 - 2008 F150 4 12-14-2014 10:56 AM
5.4 random misfire HappyRanger 1997 - 2003 F150 5 02-21-2014 02:06 AM
Engine misfire cylinder 5 and now 7/8 dsundby10 1999 to 2016 Super Duty 13 12-23-2013 06:30 PM
Missfire on cylinder 3??? Spyder2427 1997 - 2003 F150 8 06-03-2013 09:43 PM
05 F150 misfire rich exhaust smell smotherss 2004 - 2008 F150 8 03-15-2010 09:48 AM
Tags
10, 1999, 2003, coil, cylinder, engine, f250, f350, ford, forum, misfire, problems, replace, scanner, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
