major oil leak!!!!
major oil leak!!!!
I am leaking oil like crazy,,off the inspection plate and another couple drips ,,,seems to be under hpop.The valley on top under the Fuel filter bowl is puddled up and I am thinking its the hpop??/can anyone confirm this?? Just put new oil in today too
hoping it was old bad oil was causing it to drip so bad ,,it has always had a little drip but not like this.If it is hpop orings how hard is to change and what do i do???
thanks in advance 1996 ford f-350 7.3 lr diesel dually.
Having faced this same dilema...the first thing is to completely degrease the top end until it's spotless or so. Use either degreaser or brake cleaner. Once that's done get a great not good light and crank her up until you can locate the leak. It may very well be a combination of fuel and oil. Just a matter of some wrench turning don't freak out. The guys here are great if necessary you get a step by step "how to."
Read this to help you get it off and on very good write up
https://www.ford-trucks.com/forums/5...-part-1-a.html
If the discharge hose fittings or the plug on the back is leaking, you won't have to pull the pump as they can be repaired on the truck. If you have to pull the pump, you will need a new HPOP mounting gasket as it is not considered to be reusable. Some have gotten away with not replacing it but as much of a PIA it is to remove, I wouldn't risk it.
Let me know if I can help you with anything.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
