Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Lift and Level Modifications
Overview of popular modifications to customize your truck
How to tell what size lift a truck has?
Im looking at purchasing an '05 F-350 Crew Cab PSD truck at a local little dealer by me and the guy selling the truck doesnt know a lot about lifts and I myself dont know entirely much either. But is there a standard way to know exactly if a truck has like a 4,6,8 or 12 inch lift etc?
there are many different ways to "lift" a truck. One common way is to add/change springs. Another is to add bushings between the frame and the cab+bed.
both will add clearance between the center of the axle(s) and the fender. Lifts are often done to allow larger tires to be used on the vehicle.
Both my trucks are "lifted" but only because I have increased the F250 to the weight handling of a F350 and my F350 has two extra leafs (leaves?) due to using a street sand spreader in the winter, and a dump box in the summer.
any spring lift changes the angle between the transfer case and the axles. this can increase wear drive components. tho there is a tolerance.
any body lift changes what links between the cab and the frame and motor
all that to say a "lifted" truck is not necessarily a "better" truck. Some would say its not better at all but certainly a "lift" changes the stock dynamics.
Sorry, I totally didn't answer your question.. but I would look for bushings between the bed and frame and measure them or measure between the center of the rear axle to the top of the fender well on an '05 F350 crew (maybe at your local dealer?) or maybe someone here has that measurement? and then compare.
tire size will not change the distance between the center of the axle and the top of the fender-well.
unless the tire hits something on the truck when you lower it back onto the ground after changing it..
UNLESS you use different size tires on the other wheels, that will change one spring's load.
Measure from frame to axle and take that measurement and do subtraction of the factory specs for the same measurement that will give you accurate lift height ...... Then you want total height you must measure the difference between factory tire heights and fully inflated replacement tires ... This is the only and most accurate lift measurement
Thanks for your time
