FICM burn?
Old 10-07-2010, 10:53 AM
mrwrench's Avatar
mrwrench
mrwrench is offline
FICM burn?
I wanted to check the volatage:
accidentally I grounded the voltage screw( touching the screw and case) there was a spark , no fuses blown , it has 48 volt but the engine NO START.
is it possible that the ficm got burn /went bad during testing and cause a no start condition now ?
Old 10-07-2010, 11:06 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
It's possible. There is a warning abourt touching the case and the screw at the same time, but I have no clue what damage it could cause to the FICM. I know one or two that have done it and had no damage, but it can happen. You know that there is a FICM relay and 50A fuse under the hood in addition to what's in the cab, right??? In the little black box next to the brake booster. There was a picture posted yesterday of the relay and fuse. Maybe the OP will repost it if you can't figure it out?
Old 10-07-2010, 11:29 AM
Cowboy65's Avatar
Cowboy65
Cowboy65 is offline
I've also read / heard that touching the FICM case when your testing the voltage is a bad thing and normally sparks and electronics mix about as well as oil and water.
Did you check the FICM logic fuse? If the logic fuse (10A I think) is blown the injectors will still buzz when you turn the key but the engine will not start.
Old 10-07-2010, 11:38 AM
mrwrench's Avatar
mrwrench
mrwrench is offline
all the fuses are ok , and relay are ok
Old 10-07-2010, 11:39 AM
mrwrench's Avatar
mrwrench
mrwrench is offline
is there a way to test the ficm out of vehicle ?
Old 10-07-2010, 12:59 PM
Cowboy65's Avatar
Cowboy65
Cowboy65 is offline
Check out Ford TSB 08-26-3 for more FICM diagnostic info.
Also you might check with Swamps, they can provide in-depth diagnostics.
Swamp's Diesel Performance
Old 10-07-2010, 02:58 PM
mrwrench's Avatar
mrwrench
mrwrench is offline
I found coolant inside the FICM!!! accidentally dropped when I disconected the tank's hose, I think- I opened the FICM , I aplied electronics cleaner and it got dry-
Call today to Swamps diesel , thanks Cowboy65 and the guy asked me if I heard the injectors noyse . I said no when the ficm was wet but now all the noises back on again , so he said the ficm is ok . No idea what next.
Old 04-16-2011, 02:33 AM
rovidius's Avatar
rovidius
rovidius is offline
burned ficm with positive to the case
today i burned my ficm by touching the positive lead to the ficm case ,bad mistake ..done it with a long screwdriver ..discovered that i killed internal grounding inside the ficm ,if i provide external grounding the ficm will give me voltage from making the relay click but no injector noise ,discovered one small component that provides ground to other components but i assume other important components are also burned ,so i may try to do some solder just for the hack of it
Old 03-08-2024, 08:58 AM
korean powerstroke's Avatar
korean powerstroke
korean powerstroke is offline
3rd Gear
hello, can i know more result? And solution? Mine did like you did today
Old 03-08-2024, 10:07 AM
Jokester00's Avatar
Jokester00
Jokester00 is offline
Man...2 resurrections back-to-back
1. It got wet inside from coolant?
or
2. You shorted the FICM screw to the case?
If #1 - I'd pull the FICM, open the case up, and try to blow out all the moisture with some compressed air from a can. Then, leave it open inside your house for a day or so, to make sure all the moisture has a chance to dry. Then, reistall and try to start. No harm at all in doing that - just a little time lost if it doesn't work.
If #2, you have no choice but to replace the FICM or send it out to Circuit Board Medics, FICM Repair, FICM Fixer, etc. to be rebuilt.
-jokester
Old 03-08-2024, 02:24 PM
Fuzzpuss's Avatar
Fuzzpuss
Fuzzpuss is offline
I can't help but wonder how it got wet inside. My degas bottle has leaked onto the FICM multiple times, and it's never been a problem other than the crusty residue on the outside of the case.
Also, I picked-up a working FICM on ebay for less than $200. Just a thought.
Old 03-08-2024, 02:49 PM
bismic's Avatar
bismic
bismic is offline
Received 2,448 Likes on 1,696 Posts
@korean powerstroke
Not sure how much the cost is to ship FICMs from (and back to) Korea, but that is your best bet IMO (as posted on the Org).
I loaned a FICM out some years ago to a forum member and the person I loaned it to obviously did what you did. Quite a few components on both boards were damaged. Sadly he never admitted to doing it. I don't loan out stuff anymore.
The following users liked this post:
Old 03-08-2024, 03:26 PM
Fuzzpuss's Avatar
Fuzzpuss
Fuzzpuss is offline
I've had that same experience and follow-up policy when it comes to loaning tools, but I make exceptions for certain individuals.
StillNotKing
21
09-28-2021 08:19 AM
hmedic
1997-2006 Expedition & Navigator
01-15-2014 10:46 AM
08GT500
10-08-2013 02:04 PM
73f100shortbed
Bronco II
07-18-2006 06:50 PM
Quick Reply: FICM burn?
