Help with info on 6.6L - Ford Truck Enthusiasts Forums
Old 10-06-2010, 09:37 PM
cajunscout's Avatar
cajunscout cajunscout is offline
cajunscout is starting off with a positive reputation.
I've got a 92 F600 project I'm working on and need a little help. I bought this truck wrecked. I ran it out of fuel while working on it parked. From what I've found out, it probably has air in the line. I'm trying to purge it with the hand pump above the fuel filter. All I got tonight was a sputter. Any suggestions on getting it going?
I'm interested in tech info on this engine, since I plan to have this truck for a while. Is there free info out there? If not, where do I find it?
John B.
Old 10-07-2010, 12:47 AM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
I will have to look.. somewhere I put away some info on this..
Old 10-07-2010, 05:29 AM
cajunscout's Avatar
Quote:
Thanks, I'd appreciate any help you can give me.
John B.
Old 10-07-2010, 07:18 AM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
If it has the two small fuel filters mounted on the intake manifold, open the bleeder screw on that assembly and use the hand primer pump till solid fuel appears there. Then close the screw and continue to use the hand primer pump untill its difficult to pump, secure pump plunger by screwing down finger tight. Attempt to start engine.
Old 10-07-2010, 05:17 PM
cajunscout's Avatar
Quote:
It has a single filter on the passenger side with button type hand pump.
Old 10-07-2010, 05:53 PM
cajunscout's Avatar
I found this manual online, hopefully it'll get me going.
Old 10-08-2010, 08:12 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
Those are great engines. Just as said, pump it til fuel comes out, close the bleeder, pump again, and when you're cranking hold your foot to the floor. It dumps more fuel in it, and helps it start much easier.
Old 10-11-2010, 05:30 PM
cajunscout's Avatar
Quote:
I'm waitng on my book to come in to help me locate things. It should be in tomorrow. I'm hoping to get out and try it after work.
Thanks,
John B.
Old 10-12-2010, 09:10 AM
nevrenufhp's Avatar
After that, you can get to adjusting the fuel rate & timing.
Old 10-14-2010, 05:29 PM
cajunscout's Avatar
Looks like it'll be Saturday before I can get over to work on it.
I'll just be thrilled to get her cranking so I can start my build-up. This being my first diesel, I've got a lot to learn. I'll worry about the performance stuff after my builds finished and I got a few miles on her. I followed your link and read the post. It's good info.
Thanks,
John B.
Old 10-16-2010, 03:12 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
fill the fuel filter with diesel fuel or diesel kleen before you start pumping, and it will make your life a lot easier.
once you try to start it, keep the idle around 1000-1500rpm for about 1 minute, or until the engine runs clean with no sputtering. this will ensure you get all the air out of the lines. if you rev it too high before it fills everything up, you take a chance of running the filters dry before the mechanical fuel pump can fill them and purge the system of air.
Old 10-16-2010, 03:55 PM
cajunscout's Avatar
Thanks for the advise. I got tied up today, so haven't had a chance to look at it yet. I'll post my success later.
Thanks again,
John B.
Fuel pump running continously.... horseman971 1987 - 1996 F150 & Larger F-Series Trucks 10 12-03-2014 08:40 PM
starting/stalling issues with 94 F250 5.8 sleazytiki 1987 - 1996 F150 & Larger F-Series Trucks 16 05-16-2014 10:44 AM
Oil pressure after rebuild help jssparkyjr Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 14 05-03-2012 09:21 PM
In tank fuel pump spec?? dustmote 1968-2013 Full Size Vans 4 11-20-2011 07:50 AM
Diesel Fuel Additives '05Smoke 6.0L Power Stroke Diesel 18 06-21-2011 01:58 PM
Tags
1992, 250, 37341, 66, 66l, diesel, ford, forum, fuel, liter, litre, primer, pump, sale, timing, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
