1993 heavy payload package?
If the truck has a heavy duty rear axle spring package--it will have what looks like helper spring pack above the regular spring pack. It increases the payload by 400 pounds if I remember correctly.
The front springs could also be increased to 3800 pounds when the snow plow/heavy duty front spring package was ordered.
If you have the separate rear overload spring package and more than 2900 front spring package--you probably have a factory heavy duty suspension package.
Check the VIN label in the drivers side door jam for the front and rear spring capacity.
The payload is the difference between the GVW and the empty truck weight.
Lieutenant44
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-07-2016 06:14 AM
