4WD SOLENOID
Old 10-06-2010, 06:30 PM
magnet1's Avatar
magnet1
magnet1 is offline
4WD SOLENOID
I have read many threads on the 4wd solenoid from replacement to tapping on it to get you out of a jam. I try and use mine once in a while through out the summer, But I still have trouble here and there with it engaging quickly. It seems to take a little bit for the light to kick on. And the 4 LOW can really be time consuming sometimes to get in.
Is there any preventative maintainance that can be done to this set up to make the transition go easier and quicker before the snow season hits? Is there any lube or spray I can put on it to help? Even if I have to take it off to spray it, It would be worth it.
Old 10-06-2010, 08:11 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
There is an updated solenoid you can get w/ a rainhat buillt into it to deflect the water away. This is the problem they have, the rain water comes down the windshield cowl and makes it's way into the solenoid itself and corrodes it.
Old 10-07-2010, 01:17 PM
fordtruckman's Avatar
fordtruckman
fordtruckman is offline
They did this to my truck I believe because I had the same problem. Check with the....dealership... and they will know exactly what to do.
kjs5055
08-04-2016 02:42 PM
Chris82458
1999 to 2016 Super Duty
12-16-2015 01:25 PM
enosez
06-11-2015 06:23 AM
Milwaukee,WI
23
11-12-2014 05:16 AM
imlowr2
22
08-02-2011 11:22 PM
Quick Reply: 4WD SOLENOID
