Headlights Not Working - Ford Truck Enthusiasts Forums
Old 10-06-2010, 03:01 PM
short1's Avatar
short1 short1 is offline
short1 is starting off with a positive reputation.
Hey guys, the lights on my 86 stopped working the other day. Brakelights and signals work, but headlights, parking lights, markers and dash are not lighting up. No buzzing when switch is pulled on and door open/key in ignition. I checked the fuses, found one popped and replaced it. I don't know what it's for as I have no cover. I didn't notice anything change though after replacing it. Should I start with a new switch? I turns interior lights on and off. Any ideas?
Thanks!
short
Old 10-06-2010, 04:28 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Check for power at the Black/Orange stripe wire, and the Tan/White stripe wire at the headlamps switch.
If you have power to both of these, replace the switch.
If you do not have power to the Black/Orange stripe wire, check the fuse links in the engine compartment.
If you do not have power to the Tan/White stripe wire, check the fuse panel. Parking Lamp and Taillamp Fuse (15 amps)
If the fuses and links check out good, then it's wiring between the switch and fuses or links.
Old 10-06-2010, 06:18 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
From the headlight sewitch power goes to the dimmer switch, it has 3 wires. With the headlight switch on one shoud have power, the other 2 obviously go to the headlights for high and low beam. It has nothing to do with the park/ dash lights though so the headlight switch would be the most likely culprit.
Old 10-08-2010, 02:57 PM
short1's Avatar
Thanks guys! Hopefully I can get to it this weekend, i'll update when I find the problem, thanks again!
short
Old 10-08-2010, 04:04 PM
64deville 64deville is offline
64deville is starting off with a positive reputation.
Similar problem in my friends 68 Bronco. There is a problem with the high beams switch (foot operated). Try clicking that on and off with the main light switch on.
Old 10-09-2010, 12:43 AM
iwals's Avatar
iwals iwals is offline
iwals is starting off with a positive reputation.
Fuse Panel
Here is a diagram of the F150 fuse panels if you need it:
Old 10-09-2010, 10:24 PM
Be aware that that diagram is wrong where it states 1980-1981 is the same. It's not.
1981-1986 is a closer match.
1980 is a one year only.
Source: 1981 Ford Truck Owners Guide. FPS: 365-10981-B
Dash lights, tail lights out DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 9 09-19-2016 08:10 AM
1965 headlight problem mustangpt 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-22-2015 10:59 PM
No interior lights with headlights on powerstroke79 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-01-2013 08:58 AM
Dash lights CPorter 6.0L Power Stroke Diesel 0 06-05-2013 10:27 PM
Light switch wiring diagram - '88 E150 63_falcon 1968-2013 Full Size Vans 4 09-15-2006 09:40 AM
Tags
1986, 86, f150, f250, f650, ford, fseries, head, headlamp, headlights, lights, parking, problem, switch, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
