460 weak performance - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-23-2010, 02:14 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
well I got the exhaust hooked up and got the carb tuned in a little closer. After everything warmed up I hit the gas in the driveway and the tires broke loose an gravel and the frame torqued sideways slightly BADA$$ a lot of torque now and good response. No longer is my 460 dead!!
  #32
Old 12-23-2010, 05:32 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Glad to hear it's working out for you.
Post the Dyno results.
  #33
Old 12-23-2010, 06:09 PM
Jerry Hop Jerry Hop is offline
Jerry Hop is starting off with a positive reputation.
Monster Baby I think you are right with with the altitude idea.
460 Oil Filter Doesn't Fit?!?! chuffer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 09-20-2015 11:49 PM
F-250 460 very high fuel pressure Mattmason 1987 - 1996 F150 & Larger F-Series Trucks 3 07-25-2015 10:19 PM
94 460 EFI missing sgg93 1987 - 1996 F150 & Larger F-Series Trucks 10 02-10-2014 11:23 AM
Harmonic balancer should I be worried wifes65 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 21 08-14-2008 06:37 PM
85 f250 460 and hooker headers stangboy_82 Exhaust Systems 1 09-03-2003 11:24 AM
Tags
460, 48, cam, exhaust, ford, increase, inline, intermittent, light, performance, plugged, rpm, signs, spark, timing, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
