Y Block in Engine Masters - Ford Truck Enthusiasts Forums
Old 10-06-2010, 10:21 AM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
The 375" stroker ran yesterday and scored 2205 points. That puts it in 5th place overall (out of the 20 that have run so far). There are 20 engines left which will be run today and tomorrow. It has already put many modern motors to shame, including new hemis, and a Chevy LS, not to mention the numerous small blocks and big blocks of which, most are "newer" technology.
Let's hope it can hold on to that position! In any case, it's already done excellent.
Horsepower is about 524. Torque is about 477.
Old 10-06-2010, 10:43 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Great news!
Old 10-14-2010, 06:01 PM
312 312 is offline
312 is starting off with a positive reputation.
finished 16th
Old 10-14-2010, 07:43 PM
Yep. Not bad at all.
If only looking at peak horsepower, it would have finished 13th.
Old 10-15-2010, 03:08 AM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
Not too shabby for an engine that debuted under Ike!
Old 10-15-2010, 07:50 AM
Not at all!
40 engines were in the competition. At least 28 of them were bigger engines. So according to the official score, it out performed at least 12 bigger and more "modern" engines which all have many more years of development behind them.
Looking at the peak horsepower, it out performed at least 15 of those bigger more modern, more developed engines. That is simply astounding. Imagine what will be happening wen the full potential of the Y is realized.
Also, because of this competition, you will be able to order a Y that produces in excess of 1.3 hp/ci that is completely streetable, and relatively affordable. The first one being built is a 318ci stroker which is expected to produce over 450hp and have good street manners!
Decisions, decisions! Need engine choice persuasion thendrix 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 07-15-2011 12:07 PM
Cracked Block!!! (1989 7.3 IDI navistar) double ott trep Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 29 08-21-2009 11:02 PM
Y-Block out, 351W in. Which trans? 58shortbed 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-27-2004 06:37 PM
Can i stack rear blocks? 78jpa Brakes, Steering, Suspension, Tires, & Wheels 9 06-22-2004 01:01 AM
428 pistons Jamey L. Hanis FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 10-22-2003 05:36 AM
Tags
375, block, engine, ford, masters, stroker, truck, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
