You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Has anyone else had any issues with Leer caps leaking?
I have a 2011 F250 and I just put a brand new Leer 100Xl with removeable front slider window.The first time it rained after the cap was on the truck I noticed a good amount of water in my bed.I'm not sure where exactly it's coming from but along the front and about half way down both sies my carpet is wet along the bed rails.The dealer orded me all new windows if that does not fix the leak i'll be getting the cap replaced
Mine is doing the same thing! I have a 2005 HD Super Duty. I we've thad the Leer cap on it since June of 2010. I have had the truck in a couple of times for the leaking issues. In our case, I have some wetness on the bottom carpet where the cap meets the truck. I am not convinced it is the windows, but could be. The dealer claims it is getting in under the Ford bed rail caps. All of the efforts to fix the leak has been focused on that. I am schedule to have the leak(s) fixed on Saturday again. I will ask them to look at the windows as a possible source. I wil let you know how it goes.
Is there anyone out there who's Leer cap IS water tight on their Super Duty?
I also have a 100XL from Leer and from the beginning has been an issue with water coming in, appears to be from the side windows enough to cover the bottom of bed with water on a good rain
I took my truck into Leer again. This time we did a water test. We found a few things.
Tilting front window had plugged or "too small" weep holes in frame causing the frame to leak inward during heavy rain. Dealer drill the weep hole a bit. I will update once we get some good rain.
Next we focused on the bed rails and found that water was hitting the bottom of the bed rail trim from road spray. I asked Ford and was advised that most truck do not include the rear fender skirts that would help with this. Since the parts to complete this would be around $150 I chose the more economical route: expanding foam insulation spray from Home Depot.
Lastly we found more holes at the front of the bed just under where hte canopy mates to the front bed rail. There is a small hole at either side of the bed front panel where in meets the side panel. Once again I used the expanding foam to plug the holes.
I will update all once I get some time on these fixes.
I read somewhere on here that certain chemicals in the expanding foam will attack the metal and cause it to rust/corrode. I think it was in regard to someone spraying it in the cab roof cavity and it caused it to eat away at it from the inside. I don't know how true this is, but I would definitely do some further research on it before spraying it somewhere that I couldn't keep a constant eye on it. Just a thought.
I have a 2001 F-250 with a Leer 100 XL purchased in 2003 and I have had the passenger side window resealed 4 times. I am going in tomorrow for the 5th try! Needless to say I am disappointed in this model!
Leaks seem to be a common occurance with Leer. A friend of mine has a Leer on his SD and it also leaks. It seems to be at the rear. He also had trouble keeping the back glass latched while driving down the interstates. We Finally drilled holes in the bed rails and cap and bolted it down and the back glass finally will stay latched. I have an Eagle cap on my F150 and also had one on my SD with none of the issues that I've seen on Leer caps. I had an ARE cap on my 95 with no issues.
Glad I saw this post...I was just about to buy a leer cap. I think I will go with an ARE now. However I will admit the browning package on the leer would look really good on the sd
