Black Mamba Crate Motor
anybody have experiance with the Black Mamba?
Diesel Crate Motor Powerstroke-Diesel Crate Motor Powerstroke Manufacturers, Suppliers and Exporters on alibaba.com
The engine is spec. to be 425/880 not sure what the rev limit is.
Who is using this motor?
regards,
regards,
I've read about it, that's it. I don't recall who's tuning they are using for that HP/TQ spec. and rev limit is another tuning thing. I see that the price is negotiable. I'd be asking for credit for that "free" 75hp module or ask on a price for building a long block instead of a complete motor. IMHO it's really not a bad price for a complete motor though.
Not sure where you're at in NC but I can think you can do better for a lot less money from a "local" shop there.
Heres the full specs on it..
03-07 6.0L FORD POWERSTROKE STAGE II CRATE MOTOR -
THIS 6.0L POWERSTROKE BLACK MAMBA STARTS WITH A HAND-PICKED AND FULLY-TESTED SEASONED BLOCK. THE BLOCK IS THEN BORED, HONED AND MACHINED TO ACCEPT THE BALANCED ROTATING ASSEMBLY. ALL ENGINE COMPONENTS ARE INSPECTED TO ENSURE STRENGTH AND RELIABILITY.
THIS ENGINE WILL MAKE 420HP+ and 885FT/LBS OF TORQUE+ <?XML:NAMESPACE PREFIX = O /><O:P></O:P>
THIS ENGINE WILL ALSO COME WITH A FREE 75HP ELECTRONIC MODULE
03-07 SEASONED 6.0L FORD POWERSTROKE BLOCK
POLISHED CRANKSHAFT WITH STD. ROD AND MAIN JOURNALS
RODS ARE SIZED WITH NEW PISTON PIN BUSHINGS
NEW MAHLE FORGED ALUMINUM PISTONS
NEW MAHLE PISTON RING SETS
NEW HIGH PERFORMANCE ROLLER CAMSHAFT
NEW HIGH PERFORMANCE ROLLER LIFTERS
NEW CLEVITE ROD, MAIN AND CAM BEARINGS
NEW FREEZE PLUGS
NEW FLUID DAMPER
NEW INTAKE AND EXHAUST VALVES
NEW HIGH PERFORMANCE VALVE SPRINGS <O:P></O:P>
REBUILT 60HP OVER STOCK INJECTORS
REBUILT HIGH PRESSURE OIL PUMP
MELLING HIGH VOLUME LOW PRESSURE OIL PUMP <O:P></O:P>
NEW OIL COOLER
NEW ARP HEAD STUDS
ALL NEW GASKETS AND O-RINGS
NEW VALVE COVER GASKETS
NEW GLOW PLUGS
NEW CAM SENSOR
NEW HIGH VOLUME WATER PUMP
3/8 CHROMEMOLY PUSH RODS
REBUILT TURBO WITH STOCK COMPRESSOR WHEEL <O:P></O:P>
<O:P></O:P>
THIS ENGINE COMES COMPLETE WITH MANIFOLD, Y-PIPES AND TURBO BASE. YOU WILL NOT FIND A MORE DETAILED AND PROFESSIONALLY ASSEMBLY ENGINE ANY WHERE. <O:P></O:P>
WE ONLY USE THE HIGHEST QUALITY PARTS IN OUR ENGINES. <O:P></O:P>
THERE IS A $1500.00 CORE CHARGE ON ALL OF OUR DIESEL ENGINES THAT WILL BE REFUNDED WHEN A REBUILD-ABLE CORE IS RETURNED. <O:P></O:P>
<O:P></O:P>
WE ALSO MAKE A SUPER BLACK MAMBA THAT MAKES OVER 550HP. <O:P></O:P>
IF YOU NEED ANY INFO OR JUST PARTS FOR YOUR ENGINE FEEL FREE TO EMAIL . <O:P></O:P>
<O:P></O:P>
ALL OF OUR ENGINES CARRY A 12 MONTH WARRANTY. WE WILL EITHER REPAIR OR REPLACE YOUR ENGINE FOR A TIME PERIOD OF 1 YEAR FROM THE DATE OF DELIVERY PROVIDING THAT THE ENGINE HAS NOT BEEN MALICIOUSLY DAMAGED. FEEL FREE TO CONTACT US WITH ANY QUESTIONS. <O:P></O:P>
<O:P></O:P>
THANK YOU FOR YOUR TIME......AND......
ENJOY THE NOISE
NEW FREEZE PLUGS
NEW FLUID DAMPER
NEW OIL COOLER
NEW ARP HEAD STUDS
NEW GLOW PLUGS
NEW CAM SENSOR
<O:P></O:P>
<O:P></O:P>
<O:P></O:P>
<O:P></O:P>
ENJOY THE NOISE
regards,
regards,
I know a guy that has it(that's because i told him) he's had it about 6 months.So far so good strong motors.
on
155s usually are good for 90HP not the 60HP that was in the specs posted in the thread. Unless they are tuned to be "weaker" 155s. That would be why they only say 60HP.
Some of that stuff isn't really needed for 420HP+ unless the engine was really "tired".
Tex kind of what I was trying to pint out. I was thinking about what you said and given the stock motor is 325hp rated they are claiming almost 100hp. Given the injectors are 60hp that would mean either they are changing nozzels, unrating the injectors or possibly not doing anything since 420hp is possible with tuning. Hence the 75hp inline module...
on
Quite a bit of that stuff though isn't needed for the output that the engine has. You could shop around and do a little bit better then that and get more HP/TQ output as well.
Also when I see the term "Stage II" beside anything, I would expect more power output as well. Stage II injectors can for sure handle more HP then 420.
My engine mods(just the engine mods alone) come under that ~7k price tag and have more HP. Now those other mods that I don't think are warrantied might lay a better foundation for even more HP then what I have now, but it won't be a street motor anymore or it will be a street motor with no manners.
