f350 dully emergency brakes HELP!
I've taken my hub and rotor off and the emergency brake shoes have a really stiff spring behind the shoes on top plus one infront on top. I finely got it off but how do I get it back on. It is so stiff i can't spread it at all. also my front exle bearing is bad, how do you get the bearing races out then back in. I just came in fron outside and I can't figure this out. Please Help needed! Chet
Chet, I've never messed with the parking brake, but have you tried getting it on with a pair of needlenose pliers, or maybe use a standard screwdriver and lever it into place? You got it off, there has to be a way to get it on, just take a deep breath and look at it from a different angle. Good luck!
Thanks mongo75, I have tried everything. It is weird, it is on the back side of the shoes on top, then there is a weaker spring on the front on top. You can't get anything behind the shoes to stretch it. I have to try in the mornig again, I have to figure how to remove the bearing races to for new bearing, Chet
Yes a drift is a punch and thats the way I have done it for decades.I normally use a brass drift to reinstall but a normal one will work.A softer metal will prevent ant chipping
A little tip
While you are getting everything ready put the races in the freezer and take them out just when you are ready to install them.they tap in much easier when cold
A little tip
From the AARC Manual
To Install:
NOTE: Make sure the inboard brake shoe retracting spring is attached to the parking brake shoe.
1. Install the left parking brake shoe and hold-down spring, along with the inboard brake shoe retracting spring.
2. Connect the inboard brake shoe retracting spring to the right parking brake shoe, and install the right shoe and hold-down spring.
Install the brake adjuster screw and spring.
NOTE: The outboard brake shoe retracting spring mounts above the inboard brake shoe retracting spring.
3.
4. Install the outboard brake shoe retracting spring.
5. Connect the parking brake cable at the parking brake lever at the backing plate.
6. Connect the rear parking brake cable at the parking brake intermediate cable.
To Install:
3.
TyBragg
16
01-18-2014 11:44 AM
jgilrfr
17
01-17-2013 04:00 PM
Canus
06-10-2012 09:51 AM
