Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-04-2010, 09:07 PM
JTSTOY JTSTOY is offline
Garage is empty, add now
JTSTOY is starting off with a positive reputation.
Question Cleaning a bag filter???
Can anyone give me some tips on how to clean a bag filter? I just picked one (100 mic) up for my 275 gallon tote and plan on using them for magnesol filtering. But after about 25 gallons going through it into my tote tank its ready to be cleaned. So any sugestions?
  #2 (permalink)
Old 10-05-2010, 12:46 PM
TurnerBioDiesel's Avatar
TurnerBioDiesel TurnerBioDiesel is offline
2003 Ford Excursion
TurnerBioDiesel is starting off with a positive reputation.
100 micron is kinda small for a one time pass. I would start at 400 then 100 micron. When i was using bag filters that seemed to work for me. It made the smaller micron go a little further. I also used brake cleaner in a spray can to clean the bag. that should work for a wile but can be a pain. Filter bags are meant to be thrown away after full. That can get spendy.
  #3 (permalink)
Old 10-05-2010, 08:58 PM
armstrongfordtrucks armstrongfordtrucks is offline
1975 Ford F-250
armstrongfordtrucks is gaining momentum as a positive member of FTE.
Just get a filter like this. It has done 300 gal so far. This set up cost me 150.00
__________________
ARMSTRONGFORDTRUCKS
2000 F-350, XLT, CC, 4X4, AUTO. 5" STRAIGHT THRU, 6637, DP TUNER, stock, hi idle, 60 tow, decel, 80 econo, 120 race, BED LINER, GAUGES. FRESH RUST FREE FROM HUSTON TEXAS.
  #4 (permalink)
Old 10-06-2010, 12:42 AM
Hey armstrong, is that how you are filtering your raw wvo? or is that how your filtering magnesol? It looks kinda dark?
I use the 100 mic bag filter on my tote tank to pre filter my wvo before I get ready to pump it over to my processor. But the darn thing just plugs up on me. Its a pain to clean the long filter bags when they get loaded with gunk.
Thanks for your help!
  #5 (permalink)
Old 10-06-2010, 09:53 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Only filtering to 100 micron? Fabman recommended filtering down to 1 micro when using Magnesol...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #6 (permalink)
Old 10-06-2010, 11:49 AM
binuya's Avatar
binuya binuya is online now
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
I am a bit unclear as to what you are using the 100 micron filter for. Your first post mentioned using it to filter Magnesol. Like Rushmore X said, 100 micron is way too coarse.
If you are using the 100 micron bag filter for your wvo prior to processing into bio, that's overkill. (Unless there's some other reason you are choosing to do this) I use hardware store window screening to filter my wvo prior to processing. It's all you need. Cheap too.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #7 (permalink)
Old 10-06-2010, 11:54 AM
2003 Ford Excursion
oops, Should or read that closer. 100 micron will not work for magnasol. I would use a 1 micron or a centrifuge.
  #8 (permalink)
Old 10-06-2010, 03:10 PM
1975 Ford F-250
2 micron water/fuel sep from summit racing. that is wmo.
__________________
ARMSTRONGFORDTRUCKS
  #9 (permalink)
Old 10-06-2010, 05:29 PM
Ok guess I should clarify a bit. I pickup my oil from a couple spots, and its decent but always has stuff floating in it. So as it goes into the storage tote I poured it through a 100 mic bag filter that's about 14 inches long. The raw oil sits in the tote till I need to make a batch.
Then from the storage tote I pump to my processor.
I just got thinking about trying to use magnesol, and everyone on here seems to be filtering the mag in a 3 part filter setup. Everyones mic ratings seem to differ a bit, yet I'm only trying to figure out the proper ways of cleaning a filter bag. Whether its wvo or magnesol on the bag how should they be cleaned? to
  #10 (permalink)
Old 10-06-2010, 06:02 PM
  #11 (permalink)
Old 10-08-2010, 09:06 PM
Rushmore X's Avatar
2003 Ford Excursion
I'm trying turning mine inside out and using a pressure washer next time mine needs cleaning. maybe next weekend if I run another batch. will pass on how it works...
__________________
  #12 (permalink)
Old 10-18-2010, 02:48 PM
jeep1947 jeep1947 is offline
jeep1947 is starting off with a positive reputation.
Turn them inside out get the big lumps off with a garden hose. Take them to a laundry mat and wash them with detergent just like a load of clothes.
__________________
97 F250 ExtCab 2 wheel drive long bed.Mods: cOOn 10K and 6637 Air Filter. Shimmed fuel pressure regulator.3" Down Pipe Cat Ran Away. 140 volt IDM. 3rd Generation Flux Capacitor and Rolls Royce battery water. More to come.
Tags
6637, 93, bag, bags, clean, cleaning, f150, f350, filter, filters, fit, ford, idi, sock, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
