Restoration of '48-'50 F-1 gauge panel - Ford Truck Enthusiasts Forums
Old 10-04-2010, 09:46 PM
dakelm dakelm is offline
dakelm is starting off with a positive reputation.
Does anyone know the correct color(s)/process for restoring the gauge panel on the early F-1 (the panel with the round speedo hole and the four rectangular gauge openings). It looks to me like a cream or ivory color screen stenciled over a silver diamond pattern base? Is there someone who offers this service or can it be done by a do-it-yourselfer?
Doug
Old 10-04-2010, 10:55 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I don't know of anyone who restores dash pods. I've been trying to come up with a technique to replicate the diamond pattern. All of dashes I've seen restored had a flat surface.
Old 10-05-2010, 07:44 AM
hellfirejim's Avatar
hellfirejim hellfirejim is offline
hellfirejim is starting off with a positive reputation.
What about classic Instruments. I understand they restore instrument clusters. I am going to need the same thing done to mine [50 F1] and while they are at it change it all to 12v.
Old 10-05-2010, 09:35 AM
49 Ford F-1's Avatar
49 Ford F-1 49 Ford F-1 is offline
49 Ford F-1 is starting off with a positive reputation.
With mine I sanded mine down not using a lot of pressure got it cleaned all off. I then primed with a lite coat, and then painted back with the beige color. The pattern on the plate is still on there, and you can not tell it did not just come from the factory.
Old 10-05-2010, 09:54 AM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
When I redid mine, it lost the diamonds, but I am still very happy with the outcome.
Old 10-05-2010, 11:37 AM
Great picture. That is how I want mine to look. I think it is a very simple yet classically elegant design and i definately want to save mine.
Old 10-05-2010, 01:23 PM
harleymsn's Avatar
Quote:
My wife is a woodcarver and an artist, so she hand painted the gauges. I took the metal face out, cleaned and scuffed it and then sprayed with Krylon gloss Almond. I was going to use beige or ivory, but they were both much lighter than the original.
Old 10-05-2010, 01:37 PM
Looks great Harley
Old 10-05-2010, 01:44 PM
Do you recall what specific color (brand, code, etc.) you used on your dash? Did you have chance to compare it to an excellent original?
Quote:
Old 10-05-2010, 01:46 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
I'm not sure if you are aware of this or not, but they make replacement gauge face decals for the 48-50 Truck instrument panels.
I think you could remove your gauges and speedometer, then gently wet sand and paint the main panel.
Take a finished gauge to someplace that has a good selection of spray paint colors (like Home Depot) and find a cream or tan that matches (like the Krylon Gloss "Almond" Harley mentioned).
If you want it perfect, go to an auto body paint store and have them laser match it.
Here's a pic of the gauge faces from C&G Ford Parts:
https://secure435.hostgator.com/~dlv...Face Decal Kit
Old 10-05-2010, 01:52 PM
Mine is rusted to the point where I am going to have to bead blast it down to bare metal and start painting from there. If I can find the correct size screen cloth to replicate the original silver diamond pattern, I'm going to try a two color (silver base with beige top coat) process and see what happens. Are you happy with the match of the Krylon gloss Almond? Is the surface finish supposed to be glossy or more of a satin/flat? It's getting harder to find an original mint condition gauge cluster to use as a reference source.
Old 10-05-2010, 02:01 PM
harleymsn's Avatar
Quote:
The original was the same as the exterior of the truck, Palisade Green, but I opted to do the interior a darker color. What I used here on the dash was Krylon gloss Hunter Green straight out of the rattle can.
Please keep in mind, that this truck is NOT a frame off restoration, but rather intended to be a 'fun driver', with that I approached the truck with the 20 footer outlook. On the other hand, I did not want to change too much from original.
Julie, I am aware of the decals, but they don't have them with the graduations on the speedometer, so I wanted them all to be uniform. Plus, with the wife doing them, it has that 'personal' touch that I love.
Old 10-05-2010, 02:09 PM
harleymsn's Avatar
When I cleaned mine up, save the obvious rust, it had a gloss finish to it.
Old 10-05-2010, 02:22 PM
tip49's Avatar
tip49 tip49 is offline
tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.
Gauge resto
I originally stripped my cluster to bare metal, used etching primer and rattle can "tan" color so I lost the diamond pattern. I've pulled the cluster out again. I am considering re-doing either with decals and later model gauges or working around the original 6 volt gauges with 12v.
I have replaced gauge faces on both 6 volt and 12 volt meter faceplates; will re-work instrument cluster over winter after deciding on voltage supply.
Old 10-05-2010, 02:30 PM
I just wasn't sure if the Original Poster knew it.
And, they do make a set of decals with the speedometer graduations similar to yours. I believe they were used on the "Big Trucks." But the only place I've seen them for sale is on e-bay and very rarely. In typical fashion you will see them regularly until you need to buy a set.
gauge panel 1961 f100 4x4 1961 - 1966 F-100 & Larger F-Series Trucks 14 10-08-2015 06:30 AM
gauge cluster restoration 49 Ford F-1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-29-2015 09:44 AM
Aftermarket Instrument Panels F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-27-2014 09:11 AM
gauge upgrade abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 16 12-11-2013 07:54 PM
Adding gauges to a 66 Custom Cam Instrument Panel Becky_is_a_66 1961 - 1966 F-100 & Larger F-Series Trucks 12 10-14-2013 08:42 PM
Tags
12, 1950, 48, 4850, dash, f1, ford, gauge, gauges, instrument, panel, restoration, restorstion, truck, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
