badly missing 78 351m
If it has two wires, then yes it is a stator "pick up". Did you check to make sure the firing order is correct? if it is look to see if the dist. was removed it is possible it could be a couple of teeth out, it has to go two teeth so it will sit back on the oil pump shaft. also make sure that the advance moves. It is also possible that it could be locked and sending spark at the wrong time. My guess would be one of the first two, maybe someone else might have a better guess. good luck!
I took my duraspark out, got rid of the whole setup (coil & module) and put in an H.E.I dist. with everything built in. Simple one wire hook up! easy peezy trust me it's worth the scratch and far less problems. if it's not the stator or dizzy than its the module that are issues with those setups.
brown 4x4
16
03-30-2009 06:57 AM
