Rebuild cost for 390?
#31
Serving suggestion: Use the car 390 pistons with the small dish. (similar pistons are used in the truck 360) You'll have compression in the 9s, maybe 9.5 which is what they advertised in the '60s. The RV cam should work with that. Many cam write ups will tell you what compression to run. This isn't "hot rod", it was the standard sedan/station wagon motor, and those cars weighed 4000 lbs and towed all kinds of stuff. As long as you get hardened valve seats, it should be fine.
Stock pickup 390s (and 360s) have the piston about .120 down the hole--terrible for economy, but nice "don't hurt anybody" low compression.
ymmv, good luck with it.
Or go 445 stroker.....
#33
Buy a crate engine from summit, you can get a 302 for a decent price.
http://m.summitracing.com/parts/hpe-hp99f
D
D
#34
#35
nick82f100
17
02-15-2021 11:58 PM
drewduncan15
23
02-27-2018 04:29 PM
