water mark?
Old 10-04-2010, 03:28 AM
DISchkTRK's Avatar
DISchkTRK
DISchkTRK is offline
water mark?
Can someone help me with this I just got my truck bout a little over a month ago. I have washed it two times. The first time I noticed a water mark down the back of the bed from the ford emblem. Wiped it and it didn't come off. Second wash same thing but now it is hard feels like it is etched in the paint. Someone said it might be acid under the emblem from a acid wash the dealer did when it was delivered to the to clean it. What should I do to get it off? Any suggestions would be helpful. Thanks in advance.
Old 10-04-2010, 05:58 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
I would try clay bar followed up with a polish, then a sealer, then wax.
If it's not too deep/pronounced a scratch or swirl remover (Meguiars Swirl-X or Scratch-X) may remove it.
Old 10-04-2010, 06:30 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,219 Likes on 802 Posts
Is the truck still under warranty? If so, I'd point it out to the dealer and make them fix it.
Old 10-04-2010, 07:21 AM
Fishhawk460's Avatar
Fishhawk460
Fishhawk460 is offline
The issue is that the emblem is hollow and collects detergent that is not being completely flushed out. It will continue to leak out long after the truck has been washed and dried. You have to make sure when you are rinsing that you force as much water into the top of the emblem as you can to completely flush the soap out.
Old 10-04-2010, 07:25 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
And then use an electric leaf blower to blow out the water before drying (blotting) with an MF towel.
Old 10-04-2010, 07:36 AM
whalebird's Avatar
whalebird
whalebird is offline
just pry the emblem off with a butter knife
I'm kidding.
Old 10-04-2010, 10:01 AM
Fishhawk460
The back side of the emblem is really poorly designed. Instead of a solid contact point for the adhesive tape to stick to, there are raised intermittent points that the tape contacts. Therefore it isn't sealed all the way around the emblem and allows water and soap behind it.
At this point my concern isn't the white soap streak anymore but ice build up this winter. I get the feeling one day I'm going to walk behind the truck and see the emblem gone altogether.
Old 10-04-2010, 10:42 PM
DISchkTRK's Avatar
DISchkTRK
Thanks for all the advice. I had a guy try one of those waterless car cleaning applications on it for water marks, but you can still feel it. The guy mentioned it seems as tho it has ate thru the clear coat, so I am going to take it to the dealer this week. Yes it is still under warrenty tseekins ( she is only 6 weeks old) but I didn't get her from a dealer here in Hawaii. It was ordered and shippped here.
Old 10-05-2010, 05:26 AM
Fishhawk460
Keep in mind it is just hardened soap.
I used tar and bug remover plus a little elbow grease and it came right off.
Mdavidson1974
10-10-2016 03:08 AM
kevinrea
17
09-22-2016 09:21 AM
Greywolf
Projects
07-10-2012 12:32 PM
frdf250
Bio-diesel, Propane & Alternative Diesel Engine Fuels
06-07-2011 04:27 PM
The Carpathia
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-06-2011 09:49 AM
Quick Reply: water mark?
