Checking rear diff fluid level - Ford Truck Enthusiasts Forums
Old 10-04-2010, 02:13 AM
Brandynr Brandynr is offline
Brandynr is starting off with a positive reputation.
I apologize if this question has been asked before, but I couldn't figure out the search words to find it...
I have a '78 F150 with axle code H2J; I understand this to be a Ford 9" rear axle. I'm trying to figure out how you check the rear diff fluid level, or even change the fluid. Any help is greatly appreciated.
Old 10-04-2010, 02:31 AM
bobwires bobwires is offline
bobwires is starting off with a positive reputation.
these axles are great for strength, TERRIBLE for convenience.
yank the wheels and rear brakes, unbolt the axle plates and slide the axles out. drop the driveline and unbolt the carrier. replace the seal and bolt the carrier back on when the fluid is drained and wiped clean. fill up to the fill plug.
Old 10-04-2010, 09:57 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
The level is check through the fill hole. On the drivers side of the differential housing there is a 1/2" pipe plug. Remove the plug, oil should "dribble out" of the hole, if it doesn't add oil till it does.
Some (very, very few) have drain plugs. You can try a suction gun or, as bobwires suggests, drop the center section.
On yours, if the axle code is correct, you have a limited slip rear. Be sure to use the correct oil.
Old 10-04-2010, 12:40 PM
Thanks guys.
Mike, I didn't know it'd take a certain kind of oil... What do I need?
Old 10-04-2010, 01:48 PM
mikeo0o0o0's Avatar
Mobil 1 synthetic LS75W90 is a good one (note the LS prefix), you can use regular gear oil if you add a friction modifier to it. You should be able to get the additives at any auto parts store.
Just tell them you need oil for a limited slip rear, it should say on the bottle that it can be used in limied slip applications.
Just incase you don't know already H2J= (H2) Ford 9" 3.50 ratio limited slip 3750 lb capacity axle (J) w/ power steering
Old 10-04-2010, 01:53 PM
Thanks again Mike.
rear diff fluid. happscrap 1999 to 2016 Super Duty 4 11-24-2014 10:55 AM
Rear axle seal relationship to rear diff texasJ 2004 - 2008 F150 1 09-03-2014 07:19 AM
rear axle seals highboy390fe 1997 - 2003 F150 8 10-13-2011 10:48 PM
New rear diff fluid, now shakes and squeaks -lsd WizBangF350 1999 to 2016 Super Duty 4 08-02-2009 02:43 PM
front 7 rear diffs leaking? rrawlins 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-05-2003 10:00 AM
Tags
01, 2001, axle, check, diff, expedition, fluid, ford, level, location, rear, specs, sport, superduty, trac, ven
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
