Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-03-2010, 09:41 PM
1978Crew 1978Crew is offline
Garage is empty, add now
1978Crew is starting off with a positive reputation.
No choke needed on Propane Conversion
Am I remebering correctly?
No choke is needed on a dedicated propane fueled engine. Since the fuel arrives in the mixer as a gas, the atmospheric pressure equalize the mix on cold mornings, so no choke is needed.
I am planning the conversion but am currently hobbling along with the gas carb and do not want to mess with a new choke if I will not need it for propane.
__________________
1978 F250 2WD Crew Cab 351M/ C6 - SOLD
1999 F250 2WD CC LWB 7.3L 4R100: Door Ajar light Fixed, Power Locks Fixed, Rotella T6 Synthetic, Fuel Bowl Seal Kit
  #2 (permalink)
Old 10-04-2010, 02:53 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
Technically yes. Propane systems do not have a choke but most of them have a "primer" system to make up for leak down pressure losses and low cranking vacumn on cold starts.
Most systems will lose the fuel charge between the outlet of the vaporiser and the inlet of the mixer overnight so without a primer you would have a long crank when its cold, and on bigger engines in hd trucks the cranking vacumn is low so that somtimes they do not create enough to open the vaporiser so a primer gives you a "shot" of fuel to overcome this.
Hope this helps
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
Tags
1978, 1994, 360, choke, chokes, conversion, convert, engine, engines, f250, ford, needed, parts, propane, sytems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
