1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Block heater ?
Old 10-03-2010, 09:22 PM
5.4f250sd's Avatar
5.4f250sd
5.4f250sd is offline
Block heater ?
Hello out there...I have been searching for some info on where to put a frost plug heater (block heater) in my truck. I have come up with some conflictiing info. Can you guys set me straight. I need to know which frost plug it goes in. Oh and do any of you have hose heaters in a lower radiator hose? It is for the superduty in my sig. Thanks!
Old 10-03-2010, 09:39 PM
DIXIEDOG1's Avatar
DIXIEDOG1
DIXIEDOG1 is offline
Are you sure it doesn't already have one? My 2010 came stock with a block heater at no extra charge.
Old 10-03-2010, 10:27 PM
jc8825's Avatar
jc8825
jc8825 is offline
They don't come with block heaters if they are originally sold in warmer climate states.
Old 10-04-2010, 07:55 PM
5.4f250sd's Avatar
5.4f250sd
yep mine is from texas and it is being used now in northern mn and doesn't have one. Can anyone confirm where there block heater goes into the block? Which frost pug on a 06 with a 5.4. Oh and has anyone used a hose heater on the lower heater hose? Thanks!
Old 10-05-2010, 09:28 PM
5.4f250sd's Avatar
5.4f250sd
bump for help!
Old 10-05-2010, 09:33 PM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
It's a gasser...You'll be fine. I spent a winter up there and saw -55 while parking outside. Clutch was stiff as hell, but no drama.
Old 10-06-2010, 05:54 AM
barnbridge's Avatar
barnbridge
barnbridge is offline
I put a Wolverine model 16 oil pan heater on my truck and it works great. You may want a smaller one for your gasser, my oil pan holds 14 qts.
Old 10-06-2010, 07:59 AM
SlowGTA's Avatar
SlowGTA
SlowGTA is offline
I grew up a little north of you (the Iron Range) and sure as heck don't miss those winters! The only thing I go back for now is weddings and funerals It sure is beautiful country though!
I've never liked the heaters that go in the lower radiator hose. I've had a few and was underwhelmed by them. A lot of the logging equipment we used up there had oil pan heaters like barnbridge mentioned and they worked really well. Way easier to install than a block heater also, that's the route I'd go.....
Old 10-06-2010, 06:05 PM
sotwclarinetguy's Avatar
sotwclarinetguy
sotwclarinetguy is offline
The one on my 2v is at the LH rearmost softplug. This is also conincidentally one of the easier ones to get to. I would guess that it would go in the same place on yours.
Do the block heater not the hose heater. The hose heater tends to run most of the warm water through the radiator first, cooling it.
Hope this helps
Old 10-06-2010, 09:04 PM
5.4f250sd's Avatar
5.4f250sd
Thanks for all of the replies guys....tomorrow I'm going to be working on the truck and will check the Lf hand side. do you mean drivers side? I would like to go with the coolant heater... I already run synthetic oil so that should help my oil. I have seen as cold as -54 up on the range and that is partly why I would like to install this before winter. Around my house I rarely see colder than -20 but like the idea of getting in a truck the has no problem starting even in the worst elements.
Old 10-11-2010, 04:37 PM
5.4f250sd's Avatar
5.4f250sd
well I was under my truck snooping around and I am sure that I don't have one!!! I would sure appreciate some help on which plug it is in from the factory, so I can have one shipped from the site parts guy. Thanks again
Old 10-11-2010, 07:16 PM
sandmanf250's Avatar
sandmanf250
sandmanf250 is offline
block heater
put it in the easiest plug you can and plug it in,my 03 6.0 starts by itself at -20 ,and saves alot of electricity . thats a 1000 w heater unit.5w40 rotella,4 ozs of dieseal service silver cetane booster and 5 gals of kero per tank.
Old 10-18-2010, 08:13 AM
5.4f250sd's Avatar
5.4f250sd
I just bought a 600W heater for my truck. It goes into the rear driver side frost plug. I had to drain my coolant out of the radiator and there was some I lost on the driveway because I didn't know where the drain plug on the block was. Lost maybe 1/3 of a gallon. Pound the plug in with a screwdriver and the other end spins out, grab it with a pliers and pop it out. Clean off the surface to make sure that the o-ring on the heater is not damaged and add some grease to the o-ring. Slide it in so the element is at 12 o-clock, and tighten up the screw that clamps it into place. CAUTION the element is brass and with an 0-ring you don't have to tighten it up really tight. Wrought the cord keeping it away from the exhaust manifold as much as possible and zip tie it down. Fill with coolant and burp the truck by running it and monitoring the temp gauge and coolant tank. The whole job took me about 30 min. including removal and installation of the coolant. Hope this helps anyone that is in the same predicament as I was in. I bought the heater from napa and it was $42.00.
Old 12-11-2010, 12:58 AM
Thunderduckie's Avatar
Thunderduckie
Thunderduckie is offline
To late to get pics of the install but could you possibly post a pic or two of the finished product? I'd like to do this very same add and would like to know what it looks like so i get it done right.
mjms_mikey
05-15-2014 04:38 PM
IslandBlueV10
Modular V10 (6.8l)
16
12-21-2013 03:11 PM
my02ctd
1997 - 2003 F150
12-10-2013 06:45 PM
raygant
12-25-2012 10:40 PM
shore
Modular V10 (6.8l)
09-28-2009 01:37 PM
Quick Reply: Block heater ?
