E303 in 95 5.0?
on
Yes it can... but that doesn't make it a good choice in most cases. What is your definition of "better" when it comes to a cam and engine powerband? I'm sure you have already seen some of my cam suggest and I can suggest one for you too, but unless I really understand what your expectations are it's not likely you'll get what you want. For example Lew52 has this cam in his 2wd reg cab truck but he also has better heads and intake and most importantly 4.56 gears. His truck is significantly lightened as well so it's not far from being comparable to a fully loaded mustang in weight.. which is what this cam was designed for. Bottom line is it's all about the combo, and it only takes one mismatched part to completely ruin it.
on
You can have that without going as far as the E303, the Comp 35-349-8 that I have or 35-320-8 are good HO style cams that will wake the motor up without completely destroying it's usefullness in a truck. In a heavier truck or one with 31" or larger tires gears(3.73+ depending upon your combo) are also a good idea and a full exhaust system with headers should always be on the list.
on
All 5.0 motors built after 1992 come with a hydraulic roller cam from the factory, and all 5.0 blocks cast after 1987 are roller ready even if they weren't built with a roller cam from the factory. That means any '87-91 5.0 motor will accept the factory roller cam assembly(spider, dogbones, OEM roller lifters, roller cam) with little or no modifications.
Loganc95
02-25-2016 11:17 PM
ford347stroker
01-31-2014 12:05 AM
