92 f150 horn wiring - Ford Truck Enthusiasts Forums
92 f150 horn wiring
Old 10-03-2010, 09:58 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to behold
92 f150 horn wiring
i took a 93 cab and put it on a 92 and the horn didnt work. i had this problem last time and i got a wiring diagram and changed a wire and the horn worked. does anyone have access to a wiring diagram of the 93 150 cab? then i need one of the 92 f250 with a manual
thanks
Matt
Old 10-04-2010, 08:54 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
92 Horn:
1993 Horn:
Old 10-04-2010, 08:56 PM
fordboy_52's Avatar
thanks bill, but do you have one that shows the color after the horn switch listed above? i dont see anything but db? i have a solid blue and a blue and white and i think those have something to do with it
thanks
Matt
Old 10-05-2010, 07:31 AM
subford's Avatar
The 92 ground goes to G201 on a black wire.
The 93 is grounded at G200 over a black wire with a white stripe after it goes through the speed control amp in at pin #6 DG/O wire and out on pin #10 red/light blue stripe wire (same as the PSOM ground).
1993 wiring:
Old 10-05-2010, 07:59 AM
fordboy_52's Avatar
ok, for some reason i remember applying power to the blue wire and grounding the blue and white. does this make sense?
Old 10-05-2010, 08:25 AM
subford's Avatar
Quote:
No it does not. Are we talking about the 1992 or the 1993 trucks wiring.
Also do they both have speed control?
The big difference for the horn circuit between 1992 and 1993 is the speed control. The 1992 uses vacuum and the 1993 is all electric.
Old 10-05-2010, 08:09 PM
fordboy_52's Avatar
i am not concerned with the cruise, but need to get the horn working on the 92 f250 with a 93 f150 cab on it. ha
Old 10-05-2010, 08:15 PM
subford's Avatar
The ground wiring for the horn button goes through the speed control module and if you are using 1993 wiring the horn will not work without the speed control module.
If you are not using the 1993 speed control module and are using the 1993 wiring you must jumper the 6-10 pins on the speed control module plug to get the horn to work.
Old 10-05-2010, 09:00 PM
fordboy_52's Avatar
ok, i am confused as to what the speed control module is. is it something that i can swap to make the cruise work? that would be neat
Old 10-06-2010, 12:07 AM
subford's Avatar
Cruise Control is the GM term. Ford calls it Speed Control.
On a 1993 it located LH side of engine compartment, near brake master cylinder.
Old 10-06-2010, 07:49 AM
fordboy_52's Avatar
yea, on my 92 there is a huge vacum drum that is bolted to the fender wall.
97 horn not working paker 1997 - 2003 F150 0 04-11-2015 08:04 PM
Horn mdbbrown 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-17-2013 01:22 PM
Horn Horn Horn---very weak GormGorm 1987 - 1996 F150 & Larger F-Series Trucks 2 04-05-2010 12:21 AM
1987 F-150 horn problem mcne Electrical Systems/Wiring 10 10-13-2005 10:37 PM
92 f150 with cruise = horn relay country boy 1987 - 1996 F150 & Larger F-Series Trucks 11 11-08-2002 05:30 PM
Tags
150, 1992, 1997, 302, 92, 94, 95, circuit, diagram, f150, ford, horn, installation, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
