replace front rotors f150 - Ford Truck Enthusiasts Forums
Old 10-03-2010, 07:09 PM
geogman2 geogman2 is offline
geogman2 is starting off with a positive reputation.
Looking the change my front rotors on a 2004 2wd f150. I have searched the thread and can not find anything can someone direct me to a post?
Old 10-03-2010, 08:01 PM
jr105 jr105 is offline
jr105 is gaining momentum as a positive member of FTE.
The front brakes on a 2wd f150 are a one piece hub and rotor. You can either replace them with the original type or there is a kit available from Centric to convert to a 2 piece separate hub and rotor. Either one is pricey, but if you convert to a 2 piece it will be easier and less expensive in the future. Do a search for "2wd brakes " and there are discussions about this.
Old 10-03-2010, 08:25 PM
This is the kit I was talking about. You can probably find it for less money somewhere else. This was just the first one that came up when I googled Centric f150 2wd brake kit.
Zeckhausen Racing
Old 10-04-2010, 10:43 AM
Thanks for the info
Brake rotor replacement harley3348 1987 - 1996 F150 & Larger F-Series Trucks 3 03-27-2013 11:37 AM
Advice for changing brakes and rotors? tcj506 2004 - 2008 F150 40 11-12-2010 09:01 AM
removing the front rotors on 2006 f150 fender72 Brakes, Steering, Suspension, Tires, & Wheels 0 07-18-2007 12:56 AM
front rotor torque someday 1987 - 1996 F150 & Larger F-Series Trucks 3 01-13-2006 01:29 AM
front rotor torque someday Brakes, Steering, Suspension, Tires, & Wheels 1 01-12-2006 11:42 PM
Tags
03, 1997, 2007, 2008, 2wd, brakes, davidson, excursion, f150, ford, front, harley, replace, replacing, rotors, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
