Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-03-2010, 01:21 PM
Smiggles1970 Smiggles1970 is offline
Garage is empty, add now
Smiggles1970 is starting off with a positive reputation.
2008 Expedition DS Window
I noticed in the last few days that the driver side window goes down at a normal speed, but takes longer than usual to go back up. I also noticed there is a slight surging when going up. I pulled the door panel off and noticed the motor was hot. I ran the window up and down a few times and it would stop. I would wait a few seconds, hit the button again and it would continue its cycle. Is this the beginning signs of a motor failure?
  #2 (permalink)
Old 10-04-2010, 08:03 AM
CarbonClear CarbonClear is offline
CarbonClear is starting off with a positive reputation.
Not really.
I have an 07 that has done that since day one. If your concerned about it have your dealer check it.
__________________
2012 Toyota Tundra Double Cab 4x4
2007 Ford Expedtion EB
2006 Porsche Cayenne S
2004 Honda Crv
2003 Ford F350 XLT, 7.3 Diesel 4x4 (Sold)
2001 Porsche Carrera Cab
  #3 (permalink)
Old 10-04-2010, 08:41 AM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
2007 Ford Expedition
hjsimpson is starting off with a positive reputation.
Mine is also and '07, brought it to the dealer to have it replaced.
http://www.ford-trucks.com/forums/91...w-windows.html
__________________
2007 Ford Expedition XLT 4X4
Husky Liners Molded Mud Guards ~ Ford OEM Side Window Deflectors ~ WeatherTech Floor Liners & Cargo Liner
Tinted front windows ~ Hunter Bull Bar ~ HIDX 4" HID lights ~ 4" Magnaflow SS rolled angle exhaust tip
Quote:
Never, never, never give up. -Winston Churchill
  #4 (permalink)
Old 10-04-2010, 09:05 AM
n2umr n2umr is offline
n2umr is gaining momentum as a positive member of FTE.
My '07 DS window started doing that and it needed replacement shortly after. Not a bad repair though, I think it was $175 at the dealer.
Mark
  #5 (permalink)
Old 10-04-2010, 03:34 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
Mark
What was replaced exactly? Motor, regulator?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #6 (permalink)
Old 10-05-2010, 11:18 AM
They replaced the regulator I believe. What initially happened was my window was extremely slow and then finally it wouldn't go up. So I took the door panel off and found that the steel wound cable that moves the assembly was frayed and almost completely broken. The frayed part was binding inside of the cable.
I said the hell with it and took it to the dealer and I think they just replaced the regulator. The part was $124 plus an hour labor at $60. Works much better.
Mark
  #7 (permalink)
Old 01-14-2011, 10:01 PM
ZeroTucker's Avatar
ZeroTucker ZeroTucker is offline
2004 Ford F-350
ZeroTucker is starting off with a positive reputation.
Old thread but I just ran into this problem and have a cheap solution.....
I started with the usual, Petroleum along the rubber track and that didn't work. I then pulled the door panel off and greased the metal track, that didn't help either.
I found that the cable runs through a rubber sleeve and this was the culprit. I had my wife run the window up and down with the panel out of the way while I sprayed a lubricant (similar to WD-40 but has teflon in it) into the cable. As the window was ran up and down the lubricant was spread throughout the cable.
The window runs at normal speed now and the motor stays cool. The reason these motors are burning up is the cable hanging up in the sleeve it runs through. An hour of your time and some lubricant will save you the $120 the motor costs!!
  #8 (permalink)
Old 01-18-2011, 01:48 PM
berry1234's Avatar
Can you explain where the cable runs through the sleeve at? Is it near the top where the cable winds onto a plastic pulley of sorts?
__________________
  #9 (permalink)
Old 05-25-2011, 05:55 PM
thefnswits thefnswits is offline
thefnswits is starting off with a positive reputation.
I'd love to get a better description of where you're talking about. Both my front windows are doing it and squealing BAAAAD. it's pretty embarassing on my 50000 dollar truck!
__________________
1999 F250 5.4 Lariat 4x4 Off-road 8' Boss steel plow
2008 Expedition Limited everything except 3.73's and air suspension!
2007 Mitsu Fuso FG4x4 dump 9.2 Boss Vplow, 2.5 yd torwel sander
  #10 (permalink)
Old 01-19-2012, 12:16 PM
Mark E A Mark E A is offline
Mark E A is starting off with a positive reputation.
This is hilarious..I have the same thing on my 2007 Expedition. DS is worse then passengers Side. I took it to the Ford dealership and they told me it would be $1200 to fix it. I see you can get new regulators for $130 online my motors are covered under extended warranty. Think I should get motors replaced and do the regulators myself? Maybe the regulators take all week to put in for $1200...haha stupid dealership.
  #11 (permalink)
Old 01-19-2012, 12:22 PM
berry1234's Avatar
Quote:
The whole thing should be covered by warranty. Why would only the motors be?
__________________
  #12 (permalink)
Old 01-19-2012, 01:57 PM
back from dealer
Quote:
Just got back from dealer...they tell me that the motors are weak and the regulators are no good....but it is also some "tracks" that are bent and are what caused the motors and regulators to go. And yes the regulators are covered too. I told them to order the motors and regulators. I will give that a try first.....From what I have read on this forum...the tracks should have some lube in them and it doesn't come lubed from the factory. hope this is the end of window problems.
At the same time I am having the rear window wiper pivot replaced under warranty....If anyone else has this problem it is covered under ford ESP.
  #13 (permalink)
Old 01-19-2012, 02:05 PM
berry1234's Avatar
Are you putting in the motor/regulator yourself?
__________________
  #14 (permalink)
Old 01-19-2012, 02:55 PM
It is under warranty so I am going to have the dealer put them in....I think it is just $100 deductible. I am going to request them to put the lube in the tracks...if they wont put the lube in then I will take the door panel off after and lube it up myself.
berry1234 are you having this same problem? if you need help to do the fix yourself there is another thread that has photos and details. it is based on an older expedition but would be similar to 07 and newer.
  #15 (permalink)
Old 01-19-2012, 02:58 PM
berry1234's Avatar
My windows are just slower than I like. I have put plenty of lube. I just think they put inferior motors than other cars with faster windows. Takes about 5 seconds to roll it up from the very bottom.
__________________
Tags
07, 08, 2007, 2008, cable, cables, driver, expedition, ford, problems, regulator, slow, sluggish, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
