push button 4wd question?
my 95 has the push button 4wd system with manual locking hubs. I haven't had any trouble with it in the 3 years I have owned the truck. I was just curious if there is a way to shift the transfer case if the electric motor or some other part of the push button system failed? Like I said mine is working great,and I use it heavily during the winter and hunting season,would just like to know if there is anything I can do if I am deep in it and the system fails. thanks!!
THERE SHOULD BE NO QUESTIONS REGARDING PUSH BUTTON 4x4 Its the worst Idea man ever created ,,,, wait i think a woman invented that one * weak a$$ girls cant handle a stick rite Pfft .... ah ha
jayson
ASE auto electrical tech
Oh and the answer is no , because you Obd 1 or 2 controls the switch. sry mate ,
jayson
A buddy with big truck and chains comes to mind...thumb in the air if buddy isn't around to help...
With that said I'd imagine if worse ever came to worse and your shift motor crapped out you could remove the motor and shift the t-case by hand. You'd have to crawl under the truck, remove the motor, and use a little trail and error to get it shifted into 4hi or 4lo.
I've got the Borg Warner repair manual laying around somewhere, I'll see if I can find it and post up any usable info for you.
I do agree with others that the electronic shift transfer case, and auto locking hubs, were a dumb idea. If you intend to keep the truck awhile, and need to rely on your 4 wheel driving working in places a tow cant get to, then I'd highly recommend swapping in a manual case.
If you look at this, you can see the electric shift rod that comes out of the case. The electric motor spins the rod to put the case into 4by and 4low.
There are markings on the case (4h, 4l, 2, I believe) and the 'rod' actually has a trangle pointer. (see below)
Ford F150 Transfer Case Removal Photo 4
Hope this helps. Oh, btw you have to take the electric motor off to get to the 'rod' before anything eles.
Librac23
10-16-2004 10:12 AM
