302 EFI...Want more power!
search there is a millions threads on it but theres; 6 litre tune up, free flowing exhaust, I6/460 intake tube, SD friendly cam, 1.7 rockers, gt40 heads, motorcraft oil filter, auto light plugs, gap them, fuel filter, LT headers, and bump up the timing. theres so much stuff to do to these trucks just say away from cold air intakes they dont work and the I6/460 intake tube is a fraction of the price and works better. Dont waste your money on chips or spacers it wont do anything for you
I know I sound ridculously stupid, but I'm new to all this.
thanks guys,
If his 302 is the original with the 302 firing order wouldn't he have to swap the crank to a 302 HO crank with the 351w firing order to match the 351w firing order of the HO cam?
on
No.. cranks are the same for both firing orders, and same goes for the injectors on batch fired SD trucks, Ford wires the injectors the same for both firing orders, so you can swap cams with either firing order into ths motor without any other changes.
on
On a 5.0 a single 3" is plenty so if you go with duals make them 2-1/4" or 2-1/2" max to maintain some low end TQ.
I just found out i have a 91 5.0 HO Cobra motor in the truck. ( did that come in 91 tho?!?! or 93? ) If I go with 1.7 rockers... what kind of problems will I encounter. Will I clear the valve covers?! how about baffling? I got about 100k on the motor, so if I upgraded to 1.7 rockers... will I need to upgrade my springs?
what does the swap from speed density - Mass air flow consist of?
I just want my truck to have some pull and decent top end. I understand that there is plenty I can do....just don't know where to start. Or what upgrade compliments the other. I guess it all narrows down to personal preference... but I come to you guys for the years of wisdom
Thank you!
Thank you!
Last edited by Domestic_Nuwbee; 11-18-2010 at 10:50 PM. Reason: Forgot!...what will E303cam do on my motor?
on
If you buy the cast aluminum rockers the oil baffles inside the valve covers will have to be clearanced or they will hit the rockers, but otherwise there will be no problem.
Here is who im going to be going w/ for my Mass Air Conversion kit. Im sure others could enlighten you on how to do it cheaper but i don't feel like hunting down a ECU and digging out old existing wiring from a donor car or truck. Mass Air Conversion Kits « Dunne-Rite Performance
Here is another company i have been looking into going w/ also for the Mass air kit. Alil pricey but they have alot more options for you to choose from.
Interactive Systems & Technologies Mass Air Home Page
Good luck on your quest for more powa
Mario
Mario
Conanski,
I bought this truck from my brother in law, and he bought it from his coworker who is a Ford Junkie. Builds all his own vehicles and swaps motors out. In the 2yrs my bro in law owned it ( for towing boat ) he only used it 3 times. So I borrowed it once to go camping...and I could not believe how strong this truck ran! its pretty quick and pulls pretty hard. Mind you... this is coming from someone has owned nothing but Hondas and currently has a Jetta daily driver. Hence "Domestic_Nuwbee" I'm new to the v8 feild, so it all feels powerful. First time I drove it, fell in love. So I bought it off of my brother believing the potential it has. So i asked my bro to ask his coworker what they actual power plant of this truck was....ask him today actually. He said 5.0 Cobra...
