98 Explorer 4.0 EFI Fuel Pressure & Codes - Ford Truck Enthusiasts Forums
Old 10-02-2010, 01:41 PM
gwmontgomeryjr gwmontgomeryjr is offline
gwmontgomeryjr is starting off with a positive reputation.
Ive recently got a 98 Explorer with the 4.0 EFI 180k miles. Runs pretty good but Ive got some minor issues that Id like to get some opinions on.
First - codes 1151 & 1152 routinely pop up. It's been getting harder to start and runs rough for the first 30 seconds or so and then smooths out until it runs decent giving me 20 mpg with the air off. Occasionally it will idle rough and misfire at idle but that's a rare thing. I checked the fuel pressure today and it's 28 psi running at idle, about 35-38 with the vacuum line off the regulator. This is a little low per the manual which states 30-35/40-45. Also turning the key on, pressure slowly builds up and then drops down to near 0 before I start it, shutting down the pressure bleeds down to 0 in about 20 seconds.
I dont know when the fuel filter was changes last and that will be my next stop, but I also doubt that will solve the bleed down issue. It may or may not affect the pressure also. Would the concensious be more a fuel pump issue or a regulator issue? Ive got limited funds to throw at it and it is used daily. Would rather do the smartest thing if I can.
Thanks
George
Old 10-02-2010, 02:44 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Assuming you just left the 'P' off the codes, they don't make a lot of sense. Per the factory service manual, P1151 means bank 2 indicates the fuel/air ratio is correcting rich for an overly lean condition. P1152 means bank 2 indicates the fuel/air ratio is correcting lean for an overly rich condition.
Do you have the ability to monitor the STFT and LTFT numbers?
-Rod
Old 10-02-2010, 06:52 PM
Yea I left off the P from the codes.
The reader Ive got can only read the codes and reset the CEL and that's about it. There's been a couple other codes popping up occasionally but they're rare. 0171, 0174, and 0153. All O2 sensor related. I'm not so sure its an O2 sensor given thr rarity they appear and the quantity of sensors involved. Was hopeing it's be more fuel related since the pressure is on the lower side.
Old 10-02-2010, 07:31 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The lean codes are coming from the intake gaskets leaking. The hard start is caused by the fuel pump check valve bleeding down. That will be $100 for diagnosis please
LOL just kidding.
Old 10-03-2010, 12:02 AM
Ok, not what I was wanting to hear but it does make some sense. Next Q
1. How hard is it to change the Intake gaskets? I've never pulled anything off of an EFI engine. Older carb'd v8's no problem.
2. The check valve, is that part of the fuel pump located in the tank or is it somewhere more accessible....
I've got the manuals, but would like to hear from someone who's BTDT!
98 F250LD 5.4 intermitent rough idle !HELP! Brutl_Force 1997 - 2003 F150 17 08-20-2011 04:44 AM
fuel pump vs. fuel regulator... gvrangr98 Explorer, Sport Trac, Mountaineer & Aviator 15 03-16-2010 10:28 PM
hard-starting, rough idle, stalling eyancey Ford Inline Six, 200, 250, 4.9L / 300 23 09-17-2009 08:43 PM
98 Ford Ranger- rough idle at start Dmarkjohn Ranger & B-Series 4 05-15-2009 11:31 PM
Fuel pressure bleeding down Ranger GT2 Fuel Injection, Carburetion & Fuel System 3 01-14-2006 10:13 PM
Tags
02, 1997, 1998, 40, 40efi, 98, bleed, explorer, ford, fuel, idle, miss, pressure, pump, rich, sport
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
