2003 Nav VSM - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
2003 Nav VSM
Old 10-02-2010, 12:14 AM
Lemgomez Lemgomez is offline
Lemgomez is starting off with a positive reputation.
2003 Nav VSM
Ok,
First I had to argue with the parts guy at the local ford dealer that such a thing exists as a VSM on a 2003 navigator, after insisting there is one and making him look **** up, he came up with a part number of 4L1Z-15604-AD with a description of a security kit, is this the VSM? Also, anyone have experience pulling it out on a 2003? Most of the vsm references I can find in the search are for the trucks where its mounted in a different spot. I can get to the 3 connectors that go to it, but the box its self is a bit out of reach (If i'm actually looking at the right thing). Can someone confirm that hte VSM is in fact mounted on the passenger side, above the fuse box way near the top of the dash on the inside of the dash?
Old 10-02-2010, 01:42 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by Lemgomez View Post
Can someone confirm that the VSM is in fact mounted on the passenger side, above the fuse box way near the top of the dash on the inside of the dash?
That depends on what you think VSM stands for!
Abbreviations are okay, but it's good practice to use the long version once at the beginning of a message so that everyone knows they're all talking about the same thing.
For example, to you is it a Voltage Sensing Module, a Vehicle Speed Modulator, a Vehicle Service Message indicator, or a Variable Speed Module?
See what I mean!
Old 10-02-2010, 01:53 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Thank you alloro, that would insure that everyone is on the same page.
Old 10-02-2010, 03:50 PM
Well, I took apart the dash and pulled the VSM Part # on it says
2L1T-15K602-AM
RECV ASY-ALRM&LK SYS R/CONT
guess i'll go down to the ford dealer on monday and hand it to them and say, This **** is broke, and obviously it exists in my car cause here it is.
Pretty sure I got the right part in my hand, I opened it up and its a circuit card with some surface mount components and a 10 inch or so long bare wire thats soldered to the board at one end and just runs along the inside of the case (Im assuming an antenna).
Too bad I dont have access to my microminiature repair lab that I had at my last duty station, would just throw it on there and find the bad component and replace it.
First image is the inside
http://picasaweb.google.com/lh/photo...eat=directlink
2nd one is the label
Old 10-02-2010, 03:51 PM
See what I mean!
Sorry, Vehicle Security Module
aka Body security Module
Shop manual just calls it VSM in the diagram
Old 08-18-2014, 09:20 AM
usfootman usfootman is offline
usfootman is starting off with a positive reputation.
Hi! I know you opened this thread a while ago but I'm currently have exactly same issues with my 2003 nav. Have you figured out and fixed your truck? Was it VSM at all?
I experience exact same problems as you described. Power locks don't work, radio stays on, windows work after door is open, lift gate don't work and automatic lights don't work. In addition to that I think 4wd stop working and air suspension quit.
When you replaced VSM had you had to programm it? How your entire truck repair ended up?
Vsm Jzinkiewicz 1999 - 2003 7.3L Power Stroke Diesel 25 12-31-2016 01:32 PM
02 VSM board repair? artieb Excursion - King of SUVs 0 12-18-2015 09:25 AM
Is my VSM bad? DidieX Excursion - King of SUVs 10 11-10-2015 08:01 AM
What years had the VSM module? montanasteve 1999 - 2003 7.3L Power Stroke Diesel 3 10-19-2015 11:02 PM
Electrical issue-HELP! click click boom AZJD Modular V10 (6.8l) 0 06-15-2014 01:43 PM
Tags
2003, 2006, access, box, expedition, f250, ford, lincoln, locations, module, navigator, picture, security, vehicle, vsm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
