Engine Question
Engine Question
I have a 1962 Ford Unibody SWB truck. I am considering my engine options to make it a streetrod. They are asking $4995 for this engine and I was wondering if someone could help understand if this is a good buy for the price. This is my first engine to buy. I also wanted to know if it will even fit in my truck and what type of transmission should I put with it?
Below are the engine specs. It is a Ford Big Block 460 with about 512 HP
The balanced rotating assembly (typically includes crankshaft, forged pistons, rings, connecting rods, rod bearings, and balancer) featured in this engine:
This engine is custom built from start to finish in our state of the art facility by professionals that take pride in their work to guarantee that you get a top quality engine the first time!.
This engine is covered by a 1 year written warranty.
(There is no warranty when using a Blower, Turbo, Super Charger or NOS)
- 3.850" stroke cast iron crank
- 6.605" big beam forged rods with ARP rod bolts
- 10½ to 1 compression pistons
- Seasoned 2-bolt main block, vatted, magnaflux checked for cracks, thermal cleaned, steelabrated, bored and honed and plateau honed to fit new pistons
- Deck head gasket surface on block to ensure a good seal
- New CompCams Hydraulic flat tappet cam with .584"Int/.588"Exh valve lift
- Aluminum heads with 2.245"Int/1.744"Exh Cobra Jet size stainless swirl polished valves with undercut stems to improve flow - similar to Cobra Jet head
- Screw-in studs and guide plates
- New Hardened exhaust seats for use with leaded or unleaded fuel
- New 1.440" high performance springs set up to match cam
- New Spiral-type valve guides for better oil retention
- New High temperature valves seals
- New Hardened push rods
- New Adjustable roller tip rocker arms
- New Perfect Circle rings
- New Double row timing set
- New High volume oil pump with steel drive shaft and bolt on oil pickup tube
- New Brass expansion plugs
- New Edelbrock Performer RPM aluminum intake manifold. This dual plane intake constant cross-sectional area design builds low end and mid-range acceleration while optimized runner path make top-end hp
- This engine takes a square bore carb. It works best with a 850cfm carb (not included)
- All parts are painted separately before assembly for that show quality look
Engine swap mount is $110, plus you will need to back that hoss with a built up C6
LMC Truck Parts - Page 49
It's always nice to buy a motor ready to go, but you will of course save $$$$ if yu buld one up yourself. You may want to stiffen up the frame and you will more than likely have trouble getting the tires to grip...
--Mike
--Mike
1976f150dude
21
03-27-2024 09:15 PM
1976f150dude
23
10-20-2015 02:46 PM
Micbruff
23
11-05-2014 08:17 PM
