Dent side trim question - Ford Truck Enthusiasts Forums
Old 10-01-2010, 09:30 PM
Flat_Ford Flat_Ford is offline
Flat_Ford is starting off with a positive reputation.
Question Dent side trim question
I have been looking at a whole bunch or rigs and on the net...even checked in the DC and LMC catalogs but it seems that the side moulding trim on my 73 is different than most others. it's plain...doesn't have the vinyl/rubber insert running through the middle.
Does anyone else got this? Why do i have it? Is there anything special with it?
Old 10-01-2010, 09:54 PM
bendog's Avatar
bendog bendog is offline
bendog is starting off with a positive reputation.
Not terribly uncommon, my dads 79 F-250 ranger has the same stuff. Not sure I've seen it for sale. Try Jeffs bronco graveyard maybe, good luck.
Old 10-01-2010, 10:05 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Upper side mouldings without vinyl inserts: 1973/79 Customs...as an option, so not all trucks have them.
Upper side mouldings with vinyl inserts: 1973/76 Ranger/Ranger XLT's, 1977/79 Rangers.
1977/79 Ranger XLT's & 1978/79 Lariats came with "Race Track" mouldings.
The fender, door and cab corner vinyl mouldings are the same.
The quarter panel mouldings used with Race Track mouldings are unique, as their ends are different to accept the vertical mouldings that connect the upper mouldings to the lower mouldings.
The vinyl insert and the Race Track mouldings have been reproduced by Dennis Carpenter.
All these various mouldings are obsolete.
The upper mouldings without the vinyl inserts have not been reproduced. These were not offered on 1978/79 Bronco's.
The only sources for NOS parts will be a few Ford Dealers and obsolete parts vendors, ebay, swap meets and Hemmings Motor News.
Old 10-01-2010, 11:43 PM
JRon's Avatar
JRon JRon is offline
JRon is starting off with a positive reputation.
My truck is a 74 Ranger, and has the trim pictured above without the vinyl insert. I haven't looked yet, but does anyone know if you can get new clips for that trim? Its skinnier trim, so it uses smaller clips.
Thanks,
Josh
Old 10-01-2010, 11:55 PM
79FordBlake's Avatar
79FordBlake 79FordBlake is offline
79FordBlake is starting off with a positive reputation.
My 73 Ranger has the same trim as in the pic as well. One piece of mine is screwed up on the passenger side when my bed got t-boned. Still makes me sick lookin at it.
Old 10-02-2010, 12:19 AM
mine is perfect all around except for a little overspray and it needs polished...besided that i'm waiting to find the right clip for my cab corner to put them on. one clip on one side broke...
so as questioned above where to get the clips...and if anyone has an exact part number...that'd be awesome...since i'd rather know from experience than order the wrong one. thanks to all
Old 10-02-2010, 07:14 AM
Maybe this will make you feel better...
D3TZ9929038F .. Right Quarter Panel (bedside) Upper Side Moulding-without vinyl insert / Short Bed / As original, the mldg comes w/clips / Obsolete
NOS PARTS SOURCE in Lenexa KS has ONE = 913-220-5746.
No Ford Dealer, no other obsolete parts vendor has any.
Since the clips came with the mouldings, most dealers did not carry them, making it difficult to find them NOS.
Flat_Ford: Upper cab corner moulding w/o vinyl insert. There are two clips, they are different from one another. Which clip do you need-front or rear?
It may be possible to find the moulding, I need to know which side. And...I will need the last 6 digits of your trucks VIN, because there were two different mouldings used in 1973.
The 1973/79 Ford LIGHT Truck Parts Catalog is available on a CD from hipoparts.com.
v v Different strokes for different folks. I prefer the vinyl mouldings. v v
Old 10-02-2010, 07:22 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Nice looking trim. I prefer it over the style with the vinyl inserts.
Old 10-02-2010, 02:02 PM
number dummy the VIN is: F10GLR09562... My cab corner is held on with one clip and one screw and it appears factory...i will try to get a picture of it for you...
Blown 331: i'm with you i prefer this style too...if makes the truck "pop"...like chrome and paint.
Old 04-13-2013, 07:01 PM
Summerwild Summerwild is offline
Summerwild is starting off with a positive reputation.
79 f 150 moulding
I too need the same style molding for the driver side shortbox...Any ideas?
Old 04-13-2013, 07:22 PM
moldings
looking for the driver side box moulding for a 79 150 shortbox. last six numbers areEA1945...Thanks
Old 05-15-2013, 12:38 AM
molding
the ford part number is d3tz9929038f
Old 05-15-2013, 09:24 AM
Quote:
Originally Posted by Summerwild View Post
the ford part number is:
D3TZ-9929038-F .. 6 1/2' Styleside Right & Left Upper Quarter Panel (bedside) Moulding-without vinyl insert / Obsolete
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746 / No Ford Dealer, no other obsolete parts vendor has any.
Old 05-15-2013, 01:51 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Hopefully Olathe KS can hook you up with new??
But if not I have a spare long bed (yea I know you said shortbed) with that exact chrome that's good on both bed sides with mount clips.....send me a PM if interested there Summerwild.
Once you get something like 25 posts you can send and receive PM's (private messages).
Old 05-15-2013, 03:47 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Ford BODY SIDE MOLDING - Molding/Trim - C&G Ford Parts
1996 F-250 Crew Cab 4x4 (pic heavy) Zac0419 Vehicles for Sale 3 08-18-2016 06:31 AM
F350 Tahoe trip with new trailer. Warning: many photos! rangerbait Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 18 07-14-2015 02:51 PM
69 Highboy value hiusmell 1967 - 1972 F-100 & Larger F-Series Trucks 9 09-08-2014 11:33 AM
$300 Dollar 78 F250 Truck (AKA ATM Truck) and build BlueOvalDismantlers 1973 - 1979 F-100 & Larger F-Series Trucks 48 07-15-2012 05:40 PM
I call it SUPER PAINT! jg09 Paint & Bodywork 25 08-11-2008 06:22 PM
Tags
02, 197379, 1974, aluminum, courier, d3tz9929038f, f150, find, ford, mouldings, number, part, pickup, side, trim, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
