Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 10-01-2010, 04:44 PM
noreverse noreverse is offline
Garage is empty, add now
noreverse is starting off with a positive reputation.
blown reverse need diagnosis help
I have a 94 F250 4x4 last winter I got stuck & in the process of trying to get un-stuck shifted into reverse and heard a "bang" & no more reverse. Can anyone tell me what I may have broken.thanks:bela"no reverse"
  #2 (permalink)
Old 10-02-2010, 07:58 AM
dave boley's Avatar
dave boley dave boley is offline
1954 Ford F-800
My Garage
dave boley is gaining momentum as a positive member of FTE.dave boley is gaining momentum as a positive member of FTE.
Dave Boley
Quote:
If you still have low gear you probably broke the reverse idler gear. At any rate it's a problem inside the tranny and you gotta take it out and take it apart.
__________________
Darkside Dave
Those who can, build... The rest are experts...
CLICK HERE to see my stuff
www.pvpmedia.com/Fstar5397s
See My 53's (Let the fun begin...)
Scoobygator, (The dang thing is finally done and SOLD!)
  #3 (permalink)
Old 10-02-2010, 05:17 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
2002 Ford F-250
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
Quote:
2 x , Dave's right, it sucks but its time to drop the trans , hopefully you did minimal damages and will be easily fixable.
  #4 (permalink)
Old 10-03-2010, 06:06 AM
dave boley's Avatar
1954 Ford F-800
My Garage
Dave Boley
The real pain is going to be the fact that you have a 4X4 which means the extra weight and disconnection of the transfer case and front drive shaft. You have to be really careful with all those electrical connections as those connectors get hard and brittle which means the latching tabs snap off real easy. Hopefully you can get to it before it gets cold as that stuff is even worse about breaking when cold. Don't try to drop it with the shift lever attached and be sure to remove the linkage to the transfer case if it is a manual.
I have a complete tranny, bell housing and transfer case from an '83 I could stand to part with if that would be of any help bit I thing it is different than what you have.
Later Man...
__________________
Darkside Dave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
