P0175 and P0171 codes
I am getting codes P0171 and P0175 on a 2002 F-150 4.2. I have cleaned the MAF and filter, replaced the elbows on the PCV assy and checked for vacuum leaks but couldnt find anything. The truck runs a little rough at idle but doesnt seem to lack any power. It is also hard to start, especially when it has warmed up. Fuel pressure holds pretty steady 32psi at idle. I have also replaced the fuel filter and air filter. Not sure what is causing the problem, any ideas?
your positive you have the right codes.......most of the time when you get a p0171 you will get a p0174
Ok, so I had a small exhaust leak from a broken bolt on the exhaust manifold; fixed it and that seems to have gotten rid of the lean code. I still have the P0175 rich code on bank 2. The LTFT is -27 at idle and the exhaust still smells very rich. The only think I can think of is a leaking injector or something like that. Any thoughts.
dreyko
1997-2006 Expedition & Navigator
10-06-2021 11:13 AM
kdwilkes
03-03-2007 11:17 PM
