Maryland Chapter Join Chapter, Leader: BPofMD
Truck not down shifting???
Old 10-01-2010, 05:59 AM
Blade79's Avatar
Blade79
Blade79 is offline
Hey guys, got a question here. Got my motor running after replacing the rockers, and rods. When taking it for a drive I noticed that it won't down shift. It's like she's stuck in first gear. I can shift into reverse, drive, everything and you can feel her slam into gear. Transfer case shifts and works fine. Could this be the result of a bad vacuum line causing the automatic trans sensor not telling it to downshift? No check engine light has come one either...yet.
89 F-250, 351w, C-6 auto, no o/d, 4x4
Old 10-01-2010, 07:00 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
sorry to not answer sooner. ok, c6 has a metal vacum line that comes down on top of the trans, and ends at the back on the pass side.top rubber line should come off the upper plenum, and attach to the metal line. on the bottom, the rubber line comes off the metal, and goes to the modual. replace both ends. when you pull the line off the modual, see if trans fluid drips/runs out. if not, replace the rubber line, and test, if trans fluid found, post again, and I'll tell you how to fix that part.
Old 10-04-2010, 06:25 AM
Blade79's Avatar
Blade79
Blade79 is offline
OK, found the line and when I unpluged it from the modual and not fluid came out. found that it was still unhooked from the intake. Question. I'm not sure exactally where on the intake it should be pluged in though. Do you have apic that I could refer too???
Old 10-04-2010, 06:30 AM
Blade79's Avatar
Blade79
Blade79 is offline
Oh yea and the check engine light finally came on after running about 10 min.
Old 10-04-2010, 01:20 PM
dustybumpers
right on top of the plenum, there is a bunch of hoses. 1 big one, that goes to the booster, and some small ones. red to fuel pressure reg, black to heater, black to trans, and black to emissions. might be another red one, I forget, and it's raining right now. vacuum leak will give a code, and make check engine light come on, pull the codes, and see what they are before you spend any money
Old 10-04-2010, 03:01 PM
Blade79's Avatar
Blade79
Blade79 is offline
Woo Hoo, Your the man Charlie! Hooked it up and trucks shifts just fine now. Thanks! Don't ask me how I missed that but I did.
Old 10-04-2010, 03:07 PM
dustybumpers
cool. we keep this up, your going to have a new/old truck btw. other one goes to the map sensor
Old 10-05-2010, 09:28 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,080 Likes on 982 Posts
Is that something like a GPS????
Old 10-05-2010, 06:59 PM
dustybumpers
Manifold Absolute Pressure sensor
Uni Moe
02-04-2015 07:13 PM
bubbasz1
1999 to 2016 Super Duty
16
02-26-2009 06:26 PM
XolieX
02-13-2005 08:40 PM
69crewcab
06-20-2004 06:33 PM
buckskin
1997 - 2003 F150
12-31-2003 05:20 PM
Quick Reply: Truck not down shifting???
