Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 10-01-2010, 05:59 AM
Blade79's Avatar
Blade79 Blade79 is offline
1989 Ford F-250
Blade79 is gaining momentum as a positive member of FTE.Blade79 is gaining momentum as a positive member of FTE.
Truck not down shifting???
Hey guys, got a question here. Got my motor running after replacing the rockers, and rods. When taking it for a drive I noticed that it won't down shift. It's like she's stuck in first gear. I can shift into reverse, drive, everything and you can feel her slam into gear. Transfer case shifts and works fine. Could this be the result of a bad vacuum line causing the automatic trans sensor not telling it to downshift? No check engine light has come one either...yet.
89 F-250, 351w, C-6 auto, no o/d, 4x4
__________________
Rick Kerfoot
89-F250 Project truck
  #2 (permalink)
Old 10-01-2010, 07:00 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
sorry to not answer sooner. ok, c6 has a metal vacum line that comes down on top of the trans, and ends at the back on the pass side.top rubber line should come off the upper plenum, and attach to the metal line. on the bottom, the rubber line comes off the metal, and goes to the modual. replace both ends. when you pull the line off the modual, see if trans fluid drips/runs out. if not, replace the rubber line, and test, if trans fluid found, post again, and I'll tell you how to fix that part.
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Quote:
Originally Posted by 67nukeford View Post
Charlie, don't make me come there and kill you...
"If more sane people were armed, the crazy people would get off fewer shots."
  #3 (permalink)
Old 10-04-2010, 06:25 AM
Blade79's Avatar
1989 Ford F-250
Quote:
OK, found the line and when I unpluged it from the modual and not fluid came out. found that it was still unhooked from the intake. Question. I'm not sure exactally where on the intake it should be pluged in though. Do you have apic that I could refer too???
__________________
Rick Kerfoot
  #4 (permalink)
Old 10-04-2010, 06:30 AM
Blade79's Avatar
1989 Ford F-250
Oh yea and the check engine light finally came on after running about 10 min.
__________________
Rick Kerfoot
  #5 (permalink)
Old 10-04-2010, 01:20 PM
Almost Normal
1995 Ford F-150
right on top of the plenum, there is a bunch of hoses. 1 big one, that goes to the booster, and some small ones. red to fuel pressure reg, black to heater, black to trans, and black to emissions. might be another red one, I forget, and it's raining right now. vacuum leak will give a code, and make check engine light come on, pull the codes, and see what they are before you spend any money
__________________
  #6 (permalink)
Old 10-04-2010, 03:01 PM
Blade79's Avatar
1989 Ford F-250
Woo Hoo, Your the man Charlie! Hooked it up and trucks shifts just fine now. Thanks! Don't ask me how I missed that but I did.
__________________
Rick Kerfoot
  #7 (permalink)
Old 10-04-2010, 03:07 PM
Almost Normal
1995 Ford F-150
cool. we keep this up, your going to have a new/old truck btw. other one goes to the map sensor
__________________
  #8 (permalink)
Old 10-05-2010, 09:28 AM
BPofMD's Avatar
BPofMD BPofMD is online now
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Is that something like a GPS????
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #9 (permalink)
Old 10-05-2010, 06:59 PM
Almost Normal
1995 Ford F-150
Quote:
Manifold Absolute Pressure sensor
__________________
Tags
1989, 2005, c6, downshifting, f150, f250, ford, rite, shifting, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
