mercon atf - Ford Truck Enthusiasts Forums
mercon atf
Old 10-01-2010, 12:15 AM
filiruiz filiruiz is offline
filiruiz is starting off with a positive reputation.
Question mercon atf
Hi. I own a mazda tribute 2006. Because is build by Ford it requires mercon atf for the transmission. It is been very dificult to find it. Does
dexron/mercon can be used as a substitute?
Old 10-01-2010, 07:35 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
All Ford applications that previously specified Mercon have been changed to specify Mercon V as the correct replacement fluid.
Mobil-1 ATF for 4R100 kawika 1999 - 2003 7.3L Power Stroke Diesel 28 03-02-2016 09:39 PM
What kind of ATF are you using in your older Expeditions? Mercon or Mercon 5? expy37at Expedition & Navigator 5 05-26-2011 12:05 AM
ATF/Mercon, Mercon V "Brand" Info. (?) bodyelite Oil & Lubrication 19 06-28-2008 01:15 AM
Mercon V Question CougarXR02 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-04-2007 03:11 PM
Mercon ATF Gypsy 1999 - 2003 7.3L Power Stroke Diesel 11 02-29-2004 08:38 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2006, 62l, atf, automatic, expedition, f150, fluid, ford, mazda, mercon, raptor, substitute, transm, tribute, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
