Front Axel Seal - Wheel / Hub Bearing Assembly Diagram
Does anyone have an exploded assembly diagram for the front axle F250 4x4 ? Primarily for the axle tube seal, stearing knuckle assembly,wheel/hub bearing etc. I am installing nex universals,(maybe) upper/lower ball joints, then hub bearing assembly and so on.
Thanks for everyones' help !
A few post down there is the Ball Joint replacement thread and his pic are very informative.
I'm getting ready to replace my joint and when I pulled the spindle bearing i found the needle bearings had jumped their races and scored the ?? outer shaft??
I replaced this bearing about ? 4-5 years ago...and wonder if i goofed then...or if the shaft was scored then and I didn't know.
The hub then cost $500...I just found some on line for $169 but need to verify the #...it seems too good to be true.
Amazon.com: 99 00 01 02 04 FORD F250 SUPER DUTY FRONT NEW HUB WHEEL BEARING: Automotive
cw
cw
marilyne479
New Member Introductions
02-03-2007 03:35 PM
