Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-30-2010, 08:53 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Garage is empty, add now
Sullid01 is gaining momentum as a positive member of FTE.
Biodiesel, injectors and oil filters Rumors
I have heard a few rumors and I would like to know if there is any truth to them.
I have a 6.0L psd and have run B99 for the last 2 yrs with brief breaks for winter (FL) without any problems from the biodiesel.
1. I have heard that it can be hard on the 6.0L diesel injectors. I have been caught a few times with a gelled tank (unexpected cold morning with B99). I now keep a jar of b99 next to the truck. The truck definitely does not run as smooth or seem to have as much power until warm with B99 compared to dinodiesel or even b50. Once the engine is warm there is no difference. This is true even at 90+F outside.
2. I have heard B99 can dissolve the glue that holds the motorcraft oil filter together. I have done several oil changes (every 5000mi) in the last 2 yrs and I have not noticed any problems with either oil or fuel filter breakdown.
Disclosures: I buy retail b99 that is usually palm oil derived (it gels at 60F). I have a Banks Big Hoss set-up with the PDA tuner set on 6.
  #2 (permalink)
Old 09-30-2010, 11:15 PM
tempforce's Avatar
tempforce tempforce is offline
tempforce is starting off with a positive reputation.
i'd do some blending with #2 when it gets cool. you don't want thick fuel. the poor fuel spray pattern may cause fuel dilution in the motor oil.
the b99 has much more lubricity than the current #2.
if you do the research, b99 has a very narrow flash point, burn lite off temp. where #2 starts at 170'f and the heavier portions of the fuel won't light off until the flame gets over 1000'f. part of the reason #2 starts a bit easier when its cool out. b99 has a flash point near 750'f and full burn is around 890'f. this is second hand info, so i'm most likely wrong about the numbers, but the general idea is correct.
cc
sorry about the numbers, i missed a key on the bio flash point it should of been 275' this is from a couple of second hand sources...
__________________
'08' 6.7 megacab Dodge
'02' 34' Holiday Rambler TT (4sale)
26' enclosed car hauler (4sale)
'83' 2.2 diesel Ranger
'56' F100 project
  #3 (permalink)
Old 10-01-2010, 08:42 AM
Bounds-Electric's Avatar
Bounds-Electric Bounds-Electric is offline
FORD USER
2008 Ford F-350
My Garage
Bounds-Electric is gaining momentum as a positive member of FTE.
I have burn b99 for years. You need to change fuel filters every 1,000 miles when you first start using bio. than after 2 or 3 times, every 10,000. As soon as you think temp. will go down to 60*f go to b50 below 40*f go to b20 below 0*f deisel. I am running b99 chicken fat, temps could be higher or lower for you. Filters are a main part of running bio. With what I am running b99 left in truck at 32*f will freeze, look like shaved ice in filters!
I run in (97 f-250 7.3 )(2001 f-350 7.3)(2008 f-350 6.4)(1984 8.2 detroit)
__________________
2008 F-350 XLT Lariat King Ranch DRW 4x4
(Truck 172,500 miles )(New Motor at 127,000 miles)
2001 F-350 XLT Lariat DRW 4x4 (232,650 miles) Totaled
1997 F-250 XLT Lariat 4x4 (199,500 miles)
  #4 (permalink)
Old 10-01-2010, 04:47 PM
Sullid01's Avatar
Yeah I've changed the fuel filters a number of times - my truck was pretty new when I started with the bio so it wasn't that bad. I am careful now about the cool nights -last year was a bit of a freak winter in FL. Clearly stalling the truck with gelled B99 can't be good for the injectors.
Anyone ever heard of B99 dissolving the glue in the oil filter?
  #5 (permalink)
Old 10-01-2010, 05:44 PM
FORD USER
2008 Ford F-350
My Garage
Quote:
First for me. (oil or fuel filters ) I would say this is from someone making their own biodiesel!
There are things that have to be cleaned out of oils before you could burn as biodiesel. I us chicken fat based & buy from one oil company only.
As for as temp. do change before temp. drops, do not have fuel in truck,
__________________
  #6 (permalink)
Old 10-01-2010, 08:20 PM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
It would seem to me that if you have that much of a concentration of biodiesel in your crankcase, you have much bigger problems.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #7 (permalink)
Old 10-01-2010, 08:53 PM
Sullid01's Avatar
I think there are a lot of biodiesel haters out there trying to scare people (like me). Filters breaking down sounded pretty ridiculous to me, but I thought I would ask. So long as no one else is having problems, I'm happy.
  #8 (permalink)
Old 10-01-2010, 08:59 PM
FORD USER
2008 Ford F-350
My Garage
Stick with Ford filters
__________________
  #9 (permalink)
Old 10-02-2010, 10:24 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
I've never heard of this either, but there is a plausible explanation. When a diesel (or any high-compression engine) is cold, there is some amount of blow-by present. The rings do not fully 'seal' until near operating temp and simultaneously poor atomization and combustion are normal. So, when starting cold - some combustion gasses get into the crankcase and mix with the engine oil. One of the main qualities of 'diesel oil' is dispersants that keep this diesel in solution with the oil preventing separation and isolated wear, etc. There have been MANY WVO 'blenders' and 'one-tankers' over the years who learned about this the hard way. See, when SVO gets into the crankcase oil, it rapidly polymerizes and gradually 'thickens' the oil so it no longer fits in the places its needed to do its job lubricating things. Some were lucky enough to see increased wear by doing UOA's - others disassembled engine to find a cottage cheese-looking substance where oil used to be! (severe blowby from poor compression and extended oil changes - iow's SUICIDE ).
Anyway, I 'spose its possible for some poorly washed B100 (still contains methanol and or caustic) to 'attack' something like the glue inside a filter - since using B100 will result in some B100 entering the crankcase...
My advice to anyone using 'alternative fuels' is to invest $25 in a UOA to establish a 'safe' OCI and do a UOA every once in awhile after that to monitor engine wear. As a minimum, I would (and do) change oil more frequently than if I was burning dead dinosaurs. (My PSD's have just under 200k miles total running SVO .)
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
  #10 (permalink)
Old 10-02-2010, 10:33 AM
Oh yeah, the flash point of the B100 I've tested has been 240-250*F - but will vary with feedstock, etc. Flash point of VO is 600*+. (FP of diesel is from 125*-240*F) The flashpoint is almost totally insignificant in the combustion chamber. There are some pretty advanced physics at play up in there...
The cloud point/gel point for B100 will be similar to the feed stock. I have made B100 that was clear below 20*F and I've also made B100 that was SOLID at 80*...
__________________
  #11 (permalink)
Old 10-10-2010, 10:10 PM
Sullid01's Avatar
Thanks - I have been doing 4-5K oil changes, but I think I will add the UOA to the regimen to make sure I am doing enough. I am going to add a Fumoto valve with the next change to make it easier to change and test.
__________________
Dan
2006 F250 6.0L Amarillo Powermax turbo, ARP studs, IDP RR, 4" Banks exhaust - turbo back with Cat and Banks muffler, Banks intercooler, CAT ELC, Dfuser coolant filter, Racor CCV4500, Hi Idle mod, harpooned tank, some big horns, Edge CTS, Isspro Fuel pressure and SCT X3 Matt (gearheads) SRL++ for powermax, DC Power XP270 alt
  #12 (permalink)
Old 10-15-2010, 02:35 PM
tempforce's Avatar
i always pack extra fuel filters, in both rigs. the only time i've had problems with a fuel filter. was when i left my truck, un-used in the arizona desert for a couple summer months. the inline fuel filter element came loose and blocked flow. easy fix. i changed the $3 filter. this was on my old '83' ranger. the spin on filters, i've never had any problems with. so i've purchased a boat spin on fuel filter unit, for my 2nd tank. problem solved.
__________________
'56' F100 project
  #13 (permalink)
Old 11-04-2010, 07:47 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Sullid01: Where are you getting your "retail" B99? I live in Palm Bay and afik the only place to get ANY concentration of BD is at Glover's, and they told me a year or so ago that they had no way of pumping B99 into my tank, so I have just used a couple of tanks of their B20, and that said their B20 was almost .20 per gallon more than dino at my Sunoco on malabar Road, plus Glover's is kinda out of the way for me and a bit of a hassle to actually go in and buy it.....(Great folks there though!!)
__________________
Support FTE
  #14 (permalink)
Old 11-04-2010, 12:58 PM
Sullid01's Avatar
I get it from Glover. They allow you to pump it yourself. Ask the guys at the desk to show you how - there is a valve to open, a pump to turn on, reset the meter and you're good to go. Oct-March I use B50 which I mix myself in the tank. Glover also sells on road diesel - so I do 15 gal B99 and top it off with dino-diesel. Glover's B99 is usually 5-10% cheaper than dinodiesel, but I have seen it 10-15% more. You can ask prices inside or call for prices. They do a very high volume of fuel (1million gallons/month) so you are always getting fresh fuel. They go through 60,000 gal of B99 / mo last time I asked. Their B99 will gel at 50-60F so be careful. Last October I got screwed by that cold front. I now leave a mason jar of B99 out by my truck so I will know what is going on in the fuel tank.
__________________
Dan
  #15 (permalink)
Old 11-18-2012, 09:35 PM
robertcoogan robertcoogan is offline
robertcoogan is starting off with a positive reputation.
robertcoogan@me.com
Quote:
cc
Biodiesel has a flash point that starts around 266 F, but this can go higher depending on the source WVO. I have actually heard it regularly is between 350 F to 425 F.
That being said, I am on my fifteenth month running B100 homebrew in my 2006 F-250 6L, and all I did before running biodiesel was to install a more powerful fuel pump.
I do live in the high desert of Southern California (Joshua Tree), and summer temps for day/night can run 110 F/70 F and winter average about 60 F / 40 F.
I haven't had any problems. I am going to install a heated fuel filter as a precaution, though. If I do ever manage to get my family moved up to Big Bear Lake area, I will most definitely have to run a B50 at most. Temps there run 70 F/40 F (or less) for summer and 20 F/0 F in winter. Cold!
Tags
2011, 60, 67, b100, b99, bay, bio, biodiesel, deisel, diesel, engine, fl, ford, froze, palm, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
