My truck needs to pick a side of the fence
#31
#32
1. The truck is cranking way too slow.
2. As for it starting faster later in the day, is the engine temp somewhat warm?
3. It sounds like a weak starter, but it could also be bad batts or both.
4. There is also a small chance that the cables between the batteries or starter are faulty. i.e. bad ground, dirty/corroded battery cable ends.
It is possible that you have some kind of cold start problem too, but you need to address the slow cranking first, because that may be all it is.
#33
#34
#35
#36
I'd check the age of the batteries cause they may be about done. Walmart has good batteries and are cheapest if needed. 1000cca. It very well could be a combo of both starter and batts. Sorry I'm not much more help for you james. I'll bump you up for more to see anyway.
Looking at the starter, i can't really tell how old it is.
Thank you guys for all the help so far.
#37
#39
I know it will spin over faster. The thing im getting at is.. if the starter and batt's are ok and say its the injector orings. Well now im just fixing things that sure wouldn't hurt to be replaced but certainly dont need to be replaced. I'm trying to keep in mind my budget and also not take too much money away from my go fast fund. I will replace what needs to be replaced. I just need help finding out which one or both of the two that is. End of rant. Sorry guys, i'm just trying to keep money in mind here.
#41
#43
Ian, what do you suggest. I am looking at DB electrical's website. 95 for the high torque one and 75 for the replacement. Or like 189 for the replacement down at Oriellys (btw, this is not an option)
or option 3 is go get a used one. I saw one on PSN for 40 shipped. I will see if he still has it.
#44
